[Z06] Finally took some Pics!
LOVING the car... better than I ever thought it would be.. Now for some mods.
Here is the list which is being done the first week of August1 LG Pro Headers with cats coated and X pipe.
1 install headers
1 heat wrap for headers and pipes next to trans
1 spark plug wires with heat wrap
1 Vortex air intake system
1 install air intake system
1 lower and balance car ( done already)
1 LS1 edit
1 install LS1 and set programs
2 install Bar tie rod end links
1 bear end links, front
1 bear end links , rear
6 install complete Vette brake bushing kit
1 bushing kit
1 Shipping/Delivery Charges
1 S/S brake lines
3 motul brake fluid
2 replace brake lines and complete brake system flush
1 172' thermostat
1 coolant
1 water wetter
1 replace thermostat and flush cooling system
1 body stiffing plate
0.3 install plate if done when the exhaust work is done.
1 trans cooler kit (GM T1)
4 D4f redline trans fluid
5 install trans cooler kit
2 Diff fluid
1 limited slip adaptive
0.7 service diff assembly
0.5 change engine oil and filter, minor safety inspection, replace drain plug with a magnet style
1 drain plug
1 front brake duct kit. mounts and hoses
3 install brake duct kit as needed
1 rear brake duct kit. modify Z06 housing,add hose and mounting brackets
3 install kit
1 Ron Davis racing radiator with engine oil cooler
1 oil cooler lines and fittings, ( est on lines )
AFR 205 head/custom cam package, gaskets,timing chain,big valves, keepers, retainers, heavy duty valve springs
FAST 90mm Intake (Tony Mamo ported) 90mm Throttle Body (Tony Mamo ported)
1 install head and cam package
1 misc parts
1 high flow fuel injectors
1 under drive pulley set
