Headlights won't go down
Hope this helps you. Do a search and you should be able to find some more info. Especially on replacing the gear. Good luck...
When you turn the lights ON, the Dark Green wire is momentarily switched to ground by the control module (+12 on Light Green, Ground on Dark Green) which energizes the headlight motor to open.
Similarly, when you turn the lights OFF, the Light Green wire momentarily switched to ground by the control module (+12 on Dark Green, Ground on Light Green) which energizes the headlight motor to close.
Since both of your headlights are not closing, the problem is either the headlight control module or the headlight switch. Check the connectors on the control module, but chances are since it's receiving the open signal and sending an open signal to the headlights, and the connectors have both the open and close signals in them, the problem is not there. It's likely at the headlight switch.
