I just got my Kumoh ECSTS ASX.
They were mounted and balanced this morning.
The installer put 48 psi on each of the four tires arguing that on the side of the tire it says 51 psi maximum.
I told him on the stock runflat the max is at 44 and it does not mean that I have to put 40.
I asked him to put 30 on all 4 tires.
He said I was wrong.
I insisted and reluctantly he did what I asked for.
In your opinion and knowledge who is wrong?
I would get a new installer, he is an idiot, you go by the car manufactures sticker in the door jam, or the same information is available in the owner manual. 30 PSI cold is what is stated.
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Originally Posted by bsmith
go with what the car says...not the sidewall of the tire.
I would argue that the tire company would want a higher pressure for faster wear and more tire purchases. As for what the car says, it is all about handling and performance!
I set mine at 28 cold, by the time I got to work they would typicaly be around 31 or 32. On extreamly hot days, like today (107) the pressure gets around 34 after/while driving home.
I did set mine higher but the centers wore out too quickly, thats when I droped it a couple of pounds.
What is posted on the car door sill is of NO relevance once a NON-stock tire is mounted. But, if you air just about ANY tire up to the MAX pressure, or near max pressure, it will wear unevenly, as though the tire were overinflated.
Sidewall stiffness, comfort, handling preferences, all of these factors are involved, and you must decide for yourself what you are comfortable with.
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Door jam info is for OEM tires only! Most aftermarket tires will not match that info
That's why I insisted to get them at 30 cold.
I think I will keep them at this pressure.
During their life I put the run flat at 31, sometimes 32, net result as anybody can guess, the wear is on the midlle, while the sides are in very good condition.
The recommended pressure is based on the vehicle's design load limit and vehicle's tire size NOT the brand of tire that comes from the factory. The same tires are made to fit on several different vehicles. The only time you might want to differ from the recommended pressure is if you change the tire size significantly.
I am wondering about this only because on the track I run the same size tires different brands at different hot psi to get the most traction out of the tire. Some tires are 40psi while others perform better at 31 psi.
Actually thinking about it my Michelin Pilot Sport Cups run like crap with a cold PSI of 30 they have to be around 27 while the OEM runflats were good at 31 psi. Of course I did change tire size.
Ok I am confused
Bob,
optimizing you tires for use on the track is different then going to the local show and shine. We will assume you are talking about DOT street tires.
The maximum tire pressure marked on the tire sidewall refers to the pressure required to carry the maximum load of the tire, and is usually not the same as the manufacturer’s recommended tire pressure for the vehicle.
So for the average Joe out there the manufacturer’s recommended tire pressure should be used.
