Oil consumption
Old Jul 21, 2006 | 02:03 PM
frankysuarez's Avatar
frankysuarez
Default Oil consumption
I've notice that my 1999 Hardtop send me a low oil level warning when it's reaching the time to change oil (around 28% or so) I end up putting two more quarts on it. Is this normal?
Old Jul 21, 2006 | 02:55 PM
VetteLag00's Avatar
VetteLag00
2 quarts
Should burn under a quart in 5,000 miles. Many C5's don't burn any at all. You might have a problem or one hell of a leadfoot. Do you take it to the track? You may to need to get that checked out. I thought most of the oil burning cars were late 00 early 01. Somebody else will proabably chime in. I am the furtherest thing from one of the experts on this forum but I am thinking not good
Good Luck
Old Jul 21, 2006 | 10:22 PM
IMO, this is not normal. I'd say you have a problem somewhere that needs to be looked into.
Old Jul 22, 2006 | 12:12 AM
GrayC5's Avatar
GrayC5
1999-2002: Service Bulletin: Higher Than Expected Oil Consumption
Old Jul 22, 2006 | 12:21 AM
djengr's Avatar
djengr
How often do you check your oil level? Burning oil is normal in engines, the question will be the rate of oil consumption. Some cars hardly burn any. How hard you drive and have the revs up above 4k rpm makes a difference. 1 would not be alarmed at a 1/2- 3/4 qt every 3000 miles or so. You will have to determine what is normal for your engine and monitor it.
Old Jul 25, 2006 | 10:09 PM
frankysuarez
Thanks for your comments I'll check it soon. I do have a lead foot and it is my daily driving car...
Old Jul 25, 2006 | 11:17 PM
Watchful's Avatar
Watchful
From: An Englishman drinking his way through Tewksbury MA
St. Jude Donor '09
How many miles since the oil level was correct? If you've done 5000 miles, and have a heavy foot, a couple of quarts isn't outrageous. Check it often and top it off. Goes without saying that you don't want it running a couple of quarts dry.
I'm putting a quart about every 1000 miles into mine, although as noted above, the '01s are particularly prone to it. I could drive it slower, and use less oil, but a slow Corvette is otherwise known as a Kia.
To Oil consumption
