Battery Box
Old Jul 22, 2006 | 01:13 PM
jrprich's Avatar
jrprich
Default Battery Box
So with all the problems of leaking batteries in C5s, hasn't anyone built a leak proof battery box or tub to contain such leaks if they happen ?
I am thinking along the lines of the battery boxes common in boats that would fit the C5s current battery location. Could be designed in different colors, etc.
Just a thought.
Old Jul 22, 2006 | 01:38 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Sure seems like a good idea to me...
Old Jul 22, 2006 | 02:15 PM
jrprich's Avatar
jrprich
You would think that some vendor would have built these already.
Not doubt there is a built in market
Old Jul 22, 2006 | 03:39 PM
Vette_Fan's Avatar
Vette_Fan
Come on.. Lets share ideas. Now tell me what are you thinking of using as a box to begin with. I guess you can cut it down and make it fit that battery area. I'd like to know..
Old Jul 22, 2006 | 05:10 PM
jrprich's Avatar
jrprich
Hmmm,
Just in the thought process at present, haven't taken any measurements.
The ideal solution would be a vented, acid proof battery box that would slide down into the existing vette battery well and then accept the standard wet cell battery.
This would capture any acid leakage and save the wiring and computer from any damage.
I recall acid proof battery boxes on small boats.
Example:
http://www.westmarine.com/webapp/wcs...allpartial/0/0
All we need is the bottom for acid protection......like a liner. But a vendor could mold these in any color with a cool top with C5 logo or such.
Old Jul 22, 2006 | 05:16 PM
Oldvetter's Avatar
Oldvetter
Usually boat batteries have top terminals. The leaking occurrs from the side terminals. I am not sure battery boxes would be large enough to hold side terminals. Even if the were, the cables are not long enough to go over the top of these battery boxes.
Use an AGB Battery or switch to top terminal battery.
Old Jul 22, 2006 | 05:25 PM
jrprich's Avatar
jrprich
[/QUOTE]
Looks like the stock battery in a vette measures about
Length: 10.25 inches
Width: 7.25 inches
Height: 7.38 inches
Based on several battery vendor sites.
The Official Battery Size/Model/Gruop code for the Vette is a 78
Old Jul 22, 2006 | 05:32 PM
jrprich's Avatar
jrprich
Using the single example I listed, that box has
Inside dimensions: 11-1/8" x 7-3/4" x 10-1/8"
This would easily hold a side terminal vette battery. The height of the case bottom could be trimmed with a Dremel so that all you had was a open top deep tray for the battery to rest in and to catch in leakage.
But I haven't tried fitting this or checked the mounting issues.
Just an idea for a common problem.
Old Jul 22, 2006 | 05:37 PM
Oldvetter's Avatar
Oldvetter
If you get a leak from the terminals, you need a large enough volume between the battery and battery box to hold acid from terminals up in battery. That could be a lot af acid. Plus I would want the battery box to extend over the leak point (side terminals). What if you were parked on a hill, you wouldn't want the drips to miss the battery box.
There is not much room in there for a large battery box.
It's always better to prevent the problem (leaking battery) at it's source than to try to design a backup.
Engineer here.
Old Jul 22, 2006 | 05:55 PM
C5naples's Avatar
C5naples
Engineer here.
Funny, with all the engineers in the world a 100% leakproof battery has not been invented
Old Jul 22, 2006 | 06:56 PM
jrprich's Avatar
jrprich
Hence the idea for the box. As to capacity, seems most owners check their engine bays at least weekly....... and would notice sloshing acid. I would think it would take a long time to leak a lot of acid from the types of leaks that C5 owners have seen from their batteries
Old Jul 22, 2006 | 07:48 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I put a battery mat under my top post ('04) the day I got it home from the dealership. $2 for cheap insurance. From what I've read here, most, if not all leaks have been on side posts with a small amount of seepage.
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Why not : A> get a gel battery, or B> Buy a battery box from Jegs, Summit Racing or any other speed vendor or C> relocate your battery to the trunk?
Gel battery is the simplest fix, IMHO.
Old Jul 22, 2006 | 09:40 PM
jrprich's Avatar
jrprich
A. My battery is almost brand new, the previous owner had just replaced it
B. Gel batts seem to be getting a bad rap on the forum lately
C. Wouldn't want the battery inside with me, I have a coupe.......no trunk
And after all, it is just an idea about a common issue
Old Jul 23, 2006 | 08:37 AM
Y2K Corvette's Avatar
Y2K Corvette
I read alot about the gel batteries, do you guys really have good luck with them? a good friend of mine thought they were the best, but after having 2 optima yellow tops go bad on him,( 1 a year ) he went back to standard batteries, now I'm taking into consideration his cars get put up for the winter, but he pulls the batteries and brings them in and puts a full charge in them for the winter storage, my stock batteries, I've always just made sure they were charged and then just disconnected them and mine have been lasting fine, I understand you guys down in Florida can drive your Vettes year round and maybe thats the difference, just was wondering how these are getting used compared to his experience.
Bill
Old Jul 23, 2006 | 10:00 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Nice idea - but the matter (leaky battery) is better resolved by installation of a battery that doesn't leak.
My $0,02
Old Jul 30, 2006 | 03:12 PM
jrprich's Avatar
jrprich
My $0,02
Based on recent posts.........is there such a battery ?
To Battery Box
