"Charge System Fault"?
Old Jul 22, 2006 | 03:32 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default "Charge System Fault"?
My Z seems to eat batteries, just put a new one in about 10days ago, that is the 3rd one in three years. Started fine today but I have noticed the voltage is a bit lower. As Murphy's law would have it, I leant it to a friend for a wedding this morning. He just called, it is at 13.1V which is ok but he said that Charge System Fault came up on the DIC. Where is the problem?
Old Jul 22, 2006 | 03:50 PM
lager99's Avatar
lager99
St. Jude Donor '06
Did a search in tech...maybe a loose starter connection. Sounds like it isn't usually an issue to keep running. Maybe with it so hot, full a/c & stereo and he probably isn't running it as hard as I do, that it isn't getting the revs up.
I just hope it starts in an hour after the wedding...it's 1 of 5 vette's...that would be embarrasing.
Old Jul 22, 2006 | 04:53 PM
debmwb's Avatar
debmwb
Charge System Faults are normal...unless they acually set a code and log permanently. I've had many a charge system fault without a single code being set.
Old Jul 22, 2006 | 05:03 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Check your ground as well....eh.
To "Charge System Fault"?
