What does a CAGS eliminator do?
Old Jul 22, 2006 | 10:24 PM
Rifeman's Avatar
Rifeman
Default What does a CAGS eliminator do?
I researched it online and found that it eliminates the computer aided gear selection...but I don't really know what that means! Can someone give me a thorough explaination as to how the car benifits from this and what it actually means in terms of performance.
Thanks,
Chad
Old Jul 22, 2006 | 10:30 PM
Cole's Avatar
Cole
Nothing in terms of performance. CAGS makes you shift from 1st to 4th when accelerating slowly. Its an annotance and a CAGS eliminator is one of the first modififations usually applied to an MN6. It is a real PIA to not be able to stir through the gears as you wish.
Old Jul 22, 2006 | 10:56 PM
bryanZ06's Avatar
bryanZ06
I didn't mind the CAGS on my car until I was making a turn one day and needed second gear, but the computer decided I needed fourth instead. I ordered one the next day.
Old Jul 22, 2006 | 11:22 PM
JoeZ's Avatar
JoeZ
Yeah...the GM engineers apparently put CAGS (computer aided gear selection) to help with gas milage in the city. It would force you to go from 1st to 4th gear when accellerating mildly. It would only kick in basically when in 1st and under 3,000rpm. You wouldn't be allowed to shift into 2nd or 3rd, only allowing 4th.
CAGS Eliminator gets rid of this.
Old Jul 22, 2006 | 11:48 PM
rws.1's Avatar
rws.1
two approaches,
while in first always appluy more that 30% throttle or buy a cags( or skip shift) eliminator
www.corvettesofhouston.com
Old Jul 23, 2006 | 01:36 AM
CupertinoZ06's Avatar
CupertinoZ06
I have heard that even if the CAGS bypass is installed, the 1 to 4 shift light will still come on. I think I have shifted to 2nd or 3rd when the light came on before with no apparent ill effect so I think a CAGS bypass may have been installed in my Z06 by the previous owner. But does anyone know how to absolutely make sure whether a CAGS bypass has been installed or not?
Old Jul 23, 2006 | 01:46 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jul 23, 2006 | 02:10 AM
87SAM's Avatar
87SAM
With the CAGS bypass, the shift light "should" still come on as the bypass just mimics the solenoid.
Old Jul 23, 2006 | 02:34 AM
Shylor's Avatar
Shylor
You don't understand what the CAGS is? Do you own a Corvette?
Old Jul 23, 2006 | 02:56 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi beetlejuice -
Look under the car at the trans - there is a plug with a wire going into it on the drivers side - if that plug had a "dummy" plug in it and the wiring harness is tied up, then you prbably have the CAGS bypass.
This little harness simply keeps the solenoid from blocking the gate.
My tuner turned off the CAGS by putting one of the variables out of range - it just never triggers now and the light never comes on.
Just another one of myriad reasons to have a good computer tune done IMO.
best regards -
mqqn
Old Jul 23, 2006 | 06:32 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
In simple terms it means "you" want to be in control of your shift points all the time and don't need the Chevrolet Assisted Gear Selection program "helping" you...
Old Jul 23, 2006 | 11:29 AM
steve8's Avatar
steve8
Contrary to what some people say about driving it the way you are "supposed to", the eliminator comes in handy in several low speed applications. Get it, you won't regret it.
Old Jul 23, 2006 | 11:56 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Originally Posted by rws.1
two approaches,
Actually there are three approaches- two as mentioned above, and the third is to buy a $1 resistor at radio shack, install it in the plug, and put the $19 you saved into more mods!
Old Jul 23, 2006 | 04:20 PM
Shylor's Avatar
Shylor
I disagree. If you can't drive the car without a CAGS eliminator then you probably shouldn't be driving a manual trans.
Old Jul 23, 2006 | 04:32 PM
sailohio's Avatar
sailohio
Back in the old days when the Corvette was considered a gas guzzler by the ignorant masses, the Government made GM put the CAGS on the 6 speeds. Or so I'm told. I gotta think GM engineers are much smarter then that. Afterall, they built these wonderful cars, didn't they?
Old Jul 25, 2006 | 02:04 AM
Shylor's Avatar
Shylor
The Government didn't make GM do it. GM did it on their own. This way they wouldn't have to pass along a tax to the consumer, from the Government, because the car would not meet a specific gas mileage rating with CAGS.
Old Jul 25, 2006 | 07:33 AM
Tom/99's Avatar
Tom/99
With the CAGS eliminator, you have full control of all six speeds, and without it, the computer may force you to shift from first to fourth.
To What does a CAGS eliminator do?
Old Jul 25, 2006 | 12:35 PM
HummelS's Avatar
HummelS
Just don't try to shift from 1st to 2nd until you hit about 2K RPM & save the $20.
Old Jul 25, 2006 | 12:41 PM
Land Jet's Avatar
Land Jet
Default I saw this one guys thread.....
... where he had the eliminator installed and then reprogrammed the 1 to 4 shift light to activate at his preferred RPM. He then installed a really bright LED in that area of the cluster. He claimed that he used LS1 edit to reprogram the activation rpm, effectively creating a shift light. I thought that it was pretty slick.
Old Jul 26, 2006 | 10:21 PM
emquad46's Avatar
emquad46
Default Cags eliminator
Worth every penny. Simple Installation. The 1-4 shift light comes on but does nothing. You have full control to shift when you want. You will not be forced to shift to 4th at low level accelerations. It makes driving much easier.
