Need Allignment Specs Z51
Old Jul 23, 2006 | 07:49 AM
SUPERCRUZ's Avatar
SUPERCRUZ
Default Need Allignment Specs Z51
I lowered my car on the stock bolts and put on some A&A frame rail savers yesterday. I read some posts a while back giving specs for the various suspension types, FE4, Z51, Z06. I did a search but could not find what I was looking for. Would appreciate anybody out there who can provide the Z51 allignment specifications for me. I want these in hand when I go to the shop to have my coupe alligned. Appreciate the help.
Old Jul 23, 2006 | 10:23 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
any good shop will already have these.
Old Jul 23, 2006 | 11:42 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Old Jul 23, 2006 | 11:46 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
as far as factory specs, there are only 2- Z06, and non-Z06. If you're looking for handling, you can choose the Z06, however you may experience some inner edge wear on the front. Personally(and I'm a ASE tech ), I run 0 to -0.2 degrees camber in the front, 0 to + 0.05 toe in on each side(total +0.10), with caster higher on right side to compensate for road crowns. The back is corrected per factory specs! Good luck
Old Jul 23, 2006 | 12:33 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
St. Jude Donor '06
Old Jul 23, 2006 | 12:39 PM
Anthony01's Avatar
Anthony01
Don't know if this will help? Its the only thing GM provides
Document ID# 776629
2003 Chevrolet Corvette
Wheel Alignment Specifications
RPO
Operation
Service Preferred
Tolerance
Front Alignment Specifications
All
Front Individual Toe
+ 0.04
+/- 0.10
All
Front Sum Toe
+ 0.08
+/- 0.20
All
Steering Wheel Angle
0.0
+/- 1.0
FE1 & FE3
Front Individual Caster
+ 7.4
+/- 0.5
FE1 & FE3
Front Cross Caster
Within +/- 0.5
FE1 & FE3
Front Individual Camber
- 0.20
+/- 0.5
FE1 & FE3
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
FE4 (Z06)
Front Cross Caster
Within +/- 0.5
FE4 (Z06)
- 0.70
+/- 0.5
FE4 (Z06)
Front Cross Camber
Within +/- 0.5
Rear Alignment Specifications
All
Rear Individual Toe
- 0.01
+/- 0.10
All
Rear Sum Toe
- 0.02
+/- 0.20
All
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
Rear Individual Camber
- 0.18
+/- 0.5
FE1 & FE3
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
FE4 (Z06)
Rear Cross Camber
Within +/- 0.5
Document ID# 776629
Old Jul 23, 2006 | 01:21 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Thank you all. Anthony01 - Perfect, this is what I was looking for. Thanks again.
Old Jul 23, 2006 | 03:10 PM
RobWilson's Avatar
RobWilson
I went with the Z06 specs on my Z51 equipped car when I lowered it.
To Need Allignment Specs Z51
