[Z06] Plug and wire change intervals?
Old Jul 23, 2006 | 08:20 PM
GixSix's Avatar
GixSix
Default Plug and wire change intervals?
I have an 02 Z with 75000 km's on it. The car has a custom tun, vararam and borla exhaust. When should i think about changing out the plugs and wires? it runs good right now, but i really have nothing too compare it too. What plugs would you guys suggest? is this a day job or is it gonna be like my old lt1 cars where a plug and wire change can take you literally 2 days?
Thanks.
tyrel
Old Jul 24, 2006 | 02:06 AM
LIGHTNING's Avatar
LIGHTNING
i'd stick with the stock ac/delco plugs. magnecore wires are the best... hands down. ez to change both...but make sure u have a wobbly-socket wrench...got mine from snap-on...u'll need it for #8 plug.
good luck!
Old Jul 24, 2006 | 08:50 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
This gets debated over and over... If you're using platinum plugs I'd change them every 50-60k, with copper core plugs every 25-30k.
I run NGK TR-55's gapped at .055"
As for plug wires... with coil on pack ingnition the wires are very short and very efficient. The only time you will see any gain with aftermarket wires is if there is an issue with your stock ones. I have 62,000 miles on my car, most with LT headers, and still have the stock wires. I did pickup a spare set of stockers for $20.00 on here just in case one breakes while I'm changing plugs.
Re-cap... don't waste your money on new wires.
Old Jul 24, 2006 | 09:18 AM
Twil1ght's Avatar
Twil1ght
Thanks.
tyrel
You're probably going to find Denso Iridium plugs in it. That's what came in my '02. They're a touch pricey for plugs - but that's par for the course with a performance vehicle.
Old Jul 24, 2006 | 11:10 AM
GixSix's Avatar
GixSix
i also bought the car with an extra set of stock wires. So NGK's? Densos? Ac/Delco's?
lol, sounds like it's a matter of opinion but the car could probably use a new set. Another birthday present idea!
thanks.
Old Jul 24, 2006 | 03:31 PM
GixSix's Avatar
GixSix
Howabout the Berus?
http://www.zip-products.com/Corvette...AC3F29FF8FCE1E
Old Jul 24, 2006 | 03:55 PM
deathtrap's Avatar
deathtrap
my car had the densos in it, i changed them out with ngk tr6's and it made a huge diffrence
To Plug and wire change intervals?
