Tires
Old Jul 25, 2006 | 12:40 PM
tigerbb's Avatar
tigerbb
2nd Gear
Default Tires
Hello I'm A New Member Here And New Owner Of 97 C5 The Question Is The Old Owner Had 295/35/18's On The Rear Then Went To 295/30/18 To Replace. Once You Get To 45mph The Traction Light Comes On The Motor Shuts Down.everything Goes Normal When You Press The Traction Button On The Console. Do I Need To Go Back To 295/35/18 Or Computer Needs Tuning Old Owner Said This Started Happening When The Tires Was Changed
Old Jul 25, 2006 | 12:47 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
You HAVE to have about a 1/2" difference between the front and rear of the car. You need to ahve a taller tire in the rear. I've seen people get away with less than a 1/2" but that should be a good rule of thumb.
Old Jul 25, 2006 | 12:50 PM
tigerbb's Avatar
tigerbb
2nd Gear
i have 265/35/18's on the front
Old Jul 25, 2006 | 03:30 PM
FKING1's Avatar
FKING1
Same here with 295/35/18 rears. Seems to me the combo you have should work, but, I'm no expert. From an old CF thread the front to rear tire height ratio must be 96% or more or the traction control will misfunction. The 1/2" rule seems about right.
Fred
Old Jul 25, 2006 | 03:37 PM
MYCoupe's Avatar
MYCoupe
265/35/18 = 25.30" diameter
295/30/18 = 24.97" diameter
As others have stated the diameter of the rear tires should be at least 1/2" bigger than that of the front tires. You can see that that is clearly not the case here. So simple answer to your question, yes go back to 295/35/18 tires in the back and the TC will be happy once again.
Old Jul 25, 2006 | 03:42 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...or load up smaller tires on front...(not my recommendation)
To Tires
