Thunder Racing CLB not working
Old Jul 26, 2006 | 11:22 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Default Thunder Racing CLB not working
I just installed the CLB mentioned above. No matter what I do, I can't get rid of the SERVICE COLUMN LOCK message. I pulled fuse 25 (and 23 per the long sticky post on CLB's) and it wont go away.
I can hold the CLB relay in my hand... it energizes when I turn the key, and drops out in about a second. The DIC message comes on then. If I reset the DIC, the DIC is in the "trip" mode.
Also, I can start the car with the SERVICE COLUMN LOCK message on.
BTW... car is a 2004 Z06 6 speed with 2500 miles on it. No Dealer work done to it, and never had a problem with the column lock...
I give... any ideas?
Old Jul 26, 2006 | 11:51 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I can only think of two things - either the CLB is bad or somehow something got messed up in the install process. I have one of their CLBs in my 97, so I know they do work. I'd check the install steps carefully, and if you don't find anything wrong then I am sure Thunder Racing would send you a replacement....
Old Jul 27, 2006 | 01:34 AM
RFJohnston's Avatar
RFJohnston
I'm convinced that the unit either is bad, or doesn't work on a 2004. I can remove the device and the car functions normally. Reinstall it and the problem comes right back. I'll call them in the morning....
Old Jul 27, 2006 | 07:39 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
A-HA!! It appears that now I'm not the only one who has had problems AFTER installing a CLB. BTW, I got mine from "LS-1 how-to".
Old Jul 27, 2006 | 09:45 AM
TEXHAWK0's Avatar
TEXHAWK0
Question appears to have been answered in a duplicate post on TECH page. I had a TR CLB installed on my 2004 Z06 for a year with no problems or codes. I then removed the lockplate and installed one of the original GM Harness K kits (with the good relays), and it has been working for 2 years with no problems or codes.
Old Jul 27, 2006 | 11:55 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Did you follow these instuctions? http://www.ls1howto.com/index.php?ar...f4a2979a77ef4c
I didn't when I installed mine a few years ago and had the same problem. I had to put it back to stock, then followed these instuctions exactly. It's worked perfectly ever since.
Old Jul 27, 2006 | 11:56 AM
RFJohnston's Avatar
RFJohnston
Default Update
Called Thunder Racing... they said this is the 2nd one they have had this month that didn't work on a 2004 Z06. They said they needed to check on something and call me back, so I will wait to hear from them.
Cscokd sent me directions to solve the problem. (Thanks John!) I'm going to wait to change anything further until I hear back from Thunder Racing.
More later...
Old Jul 27, 2006 | 12:39 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I got mine from TR also, and installed on my '04 Z06 without a problem.
Maybe just a bad one.
Old Jul 28, 2006 | 11:00 PM
RFJohnston's Avatar
RFJohnston
That was Wednesday the 26th... called Thinder Racing today... They say they are "researching the situation." I say What is there to research? This certainly isn't a new problem... Will try the tip I got from Cscokd tomorrow, and if this doesn't work, I'll put it back to stock. I hate user created problems where none existed... not to mention nonexistant support.
Old Jul 29, 2006 | 02:54 PM
RFJohnston's Avatar
RFJohnston
Originally Posted by Cscokd
Yes....I'll tell you exactly what to do. Your CLB is working just fine. Your 2004 has the relay mod installed from the factory... PM me with your email address and I'll send you instructions on how to remove this relay circuit.
John
Thank you John! You were right. The relay mod was factory installed, and caused the problem. I removed the relay and put the jumper in and it worked like a charm. I owe ya a cold one at the next Santa Clara Corvettes meeting...
Old Jul 29, 2006 | 05:03 PM
Cscokd's Avatar
Cscokd
I love to hear success stories. Glad you're good to go now!
Cheers,
John
Old Jul 29, 2006 | 05:07 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Glad it worked out, my CLB from TR has been in my 03 Z for a little over 2 years and it works like a charm.
To Thunder Racing CLB not working
