lowering question......
Jul 27, 2006 | 12:24 AM
I lowered my car front and back longer bolts in the rear, and cut the bushings in the front and backed off the bolts as far as they go.
The question is.... My front passenger is 1/2" higher than the driver??????
Any ideas????
Tom
Jul 27, 2006 | 02:15 AM
Where did you measure from? Wheelwell is not that accurate, measure frame points and see where you are and if you still have the difference.
Jul 27, 2006 | 10:49 AM
I messured from the ground to the wheel well. and I messured from the wheel well to the top of the tire.
Quote:
Jul 27, 2006 | 11:03 AM
St. Jude Donor '06-'07-'08-'09
you measure from the frame to a level floor. You want the frame level across the front and rear and about 1/4" rake from front to back. Measure at the factory jacking points on the side of the frame.
Jul 27, 2006 | 11:50 AM
Cruise-In IV Veteran
Cruise-In V Veteran
Any ideas????
Tom
HA! mine is also, let me know if you figure it out...i have been fighting this for over a year
Jul 27, 2006 | 04:02 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That is normal. Adjust each side until it is even. Grond was the same - had to raise one side to even it out.
Jul 27, 2006 | 04:11 PM
Cruise-In V Veteran
Quote:
not possible in my case...i adjusted the low side a ton and it made no difference
i am starting to wonder if i have that sagging panel that i've heard about
Jul 27, 2006 | 04:13 PM
Quote:
Jul 27, 2006 | 04:22 PM
What is the saging pannel. can it be fixed???
Jul 27, 2006 | 04:41 PM
No clue. My panels were fine. I was agreeing that you should measure from the jacking points on level ground
Jul 27, 2006 | 04:48 PM
Cruise-In V Veteran
i think i misinterpreted a tsb that i read
Jul 27, 2006 | 07:52 PM
Any ideas????
Tom
You can measure from the high point of the fenderwell and down or from the frame and down but it won't matter. The reality is your left front is a tad lower than the right. So is mine.
When I installed Z06 springs the heights were the same as before.
You can adjust all four corners a tad to compensate.
All frames are
NOT created equal.......... apparently!
