DIC Button LED Question
Old Aug 3, 2006 | 12:58 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Default DIC Button LED Question
Just got my vert back from the dealer this afternoon after two days worth of repairs. They only missed one thing that I asked to be done, and that was to replace the LED that illuminates the bottom two buttons on the DIC. How tough is it to remove those buttons to get at the LED and how tough is it to remove and replace that LED? I may just do it myself rather than schedule another service call... TIA.
Old Aug 3, 2006 | 12:15 PM
JMc's Avatar
JMc
Anybody???
Old Aug 3, 2006 | 12:57 PM
BlueDream's Avatar
BlueDream
Best info on doing that would be at www.spdkilz.com. This has detailed instructions on placing blue LED's in various electonics in the C5 (door panel window controls, HVAC display and DIC controls). That will show you how to get to the existing lights and what to do to change the bulbs, etc. Very first item under "Tech Tips" is DIC LED install.
Good luck.
Old Aug 3, 2006 | 01:16 PM
JMc's Avatar
JMc
Thank you very much for the link. Oh Jeez... A 41 step procedure?!!! Ugh... No thanks. I can see now why the dealership "accidentally" forgot to perform this repair. It would have taken them awhile... I had no idea that the entire gauge cluster would have to come out!! Well, I've still got a year and 12k left on my GMPP warranty... There's always next time...
I was really hoping it would be a "just pull off the buttons, they pop right off, twist the bulb counter-clockwise a half a turn and it pops right out!" sort of deal.
Old Aug 3, 2006 | 03:47 PM
BrianWe's Avatar
BrianWe
Thats really all there is to it. Unfortunately, you do have to remove the cluster which is what makes for the long process. The stock bulbs are not actually LED's. They are just 12V bulbs.
Old Aug 3, 2006 | 04:55 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just another reason to make the dealership do it.
Old Aug 3, 2006 | 10:56 PM
SilverC54me's Avatar
SilverC54me
This is a do it your self project. It would take about an hour to remove the IP to replace the light.
If you want to all of the lights behind the controls can be changed out to LEDs within 3 hours or less. As was posted earlier all of the instructions with pictures are on www.spdkilz.com.
If you want help changing these just PM me.
Gary
Old Aug 3, 2006 | 11:31 PM
JMc's Avatar
JMc
Oh-oh Gary. Be careful what you offer. You busy a week from Saturday? Ha ha. Are the LED's dimmable? If I wind up having to go through all this effort, I might just go that route. But all kidding aside, thank you for the offer of help but I think I'm probably just going to have the dealer "deal" with it at some point. My problem is if I went the LED route, I'd want to do it ALL.
Old Aug 3, 2006 | 11:43 PM
SilverC54me
I have time the last Saturday of the month. I have my Vette interior done in LEDs. If you want to see it before doing the installation, there is a car show/gathering at Fudruckers on El Toro Rd in Lake Forest just off the 5 FWY every Tuesday from 5 to ???. On the days that I go, I get there by 6:45PM.
Gary
Old Aug 4, 2006 | 10:10 AM
diyguy's Avatar
diyguy
Just and FYI... If you plan to just replace the factory bulbs, make SURE your dealer carries them in stock. I have found they are a VERY difficult item to find in stock.
You can get them from GM parts direct. part # is 16057072 They run about $2.25 each from parts direct. Local parts counter is $4.50 each. There are also 4 very tiny bulbs on the left side that illuminate the HUD and dimmer controls. I don't have that part number handy, but if wanted, let me know... I can look it up.
If you convert to LED's you can remove the bulb from the socket and re-use them...just be carefull. I've seen some that are fairly brittle while working with them.
Old Aug 4, 2006 | 12:21 PM
JMc's Avatar
JMc
Good info. Thanks, guys. A Fudruckers burger sounds good. I haven't had one in a long time. I just may drive out Tuesday to say hello and check out your LED's. If so, I will send you a PM to make sure you're going to be there, first. Thanks.
I am curious about the regular stock bulbs, though... Are they prone to failure? I'm not sure I want to hassle with replacing the stock bulb (even with the dealer doing it) if others are going to start buring out anyway. At least LED's would presumably last a lot longer than the stockers, right?
Old Aug 4, 2006 | 12:54 PM
diyguy's Avatar
diyguy
I think it would be safe to say the LED's would last nearly forever. I've not seen a whole lot of these small accessory bulbs burn't out. That may, in part, be why none of the Chevy dealers carry them as standard stock parts. Every time I've needed some, I've had to order. No-one in the Dallas area carries that bulb in stock.
The change out is actually pretty easy once you get the hang of it.
Old Aug 5, 2006 | 09:06 AM
Dr. Dan's Avatar
Dr. Dan
Been there done that, and with the help of Bill (diyguy) and Carlton (spdklz) it looks great! DIC, HVAC, Stereo, Door switches, AH/TC...All of it (except below the mirror-I like the light).
To DIC Button LED Question
