My right front fender need adjusting. Anyone have a GM or 'other source' drawing that shows all the mounting screw locations. The upper ones in the engine bay are self evident. There are more, some. I am sure. hard to find. I just want to get it repositioned correctly and not risk breaking something because I missed loosening a screw.
No drawing, but I can tell you where they are at - there are 4 or 5 behind the front wheel, kind of in front of where your feet would be - look behind the front wheel, kind of like you are trying to look at the drivers feet, and you will see them -
There is one about in the middle of the wheel well, kine of directely above the center of the tire -
Then there are two that connect the fender to the front fascia - on is on the verticle fender/fascia edge, and the other is on the horizontal fender/fascia edge - you kind of have to work your entire arm between the headlight (in it's closed position) and the front fascia to get to either of these.
