Need help with codes
Old Aug 5, 2006 | 09:12 PM
wolfman04's Avatar
wolfman04
Default Need help with codes
I keep getting two codes one is BO361 H C Left Actuator Feedback Short to GND and BO441 H C Left Actuator Out of Range can anyone tell me what they mean? I know that H stands for history and C is for current.
Old Aug 6, 2006 | 07:56 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
These are for your HVAC control module. I've attached two descriptions and diagnostics from the service manual below. If you search on the forum (especially the B0441) you will see that these are somewhat common. It is likely that you need to replace your HVAC Actuator control module. I have also attached a document on the replacement of the module.
Paul
File Type: doc
File Type: doc
