C5 window problem
Old Aug 10, 2006 | 05:14 PM
thegame's Avatar
thegame
Default C5 window problem
Damn it, I just noticed on my car passenger side that the "weather stripping" I believe is all loose and coming off Where could I take the car to get this fixed ? At first I was thinking the glue probably wore of but at closer inspection it doesn't look like they use any kind of glue or adhesive anyway. I hate little stuff like this, drives me nuts
^^^^ Right at the top of the window that soft black material
Old Aug 10, 2006 | 06:09 PM
thegame's Avatar
thegame
ttt cause im an **** owner
Old Aug 10, 2006 | 06:52 PM
rcs128's Avatar
rcs128
Are you talking about the rubber weatherstripping around the upper 3 edges or the trim that's attached to the door? If you're talking about the door, I think it woudl be easy to get new trim and put it on the door... I had my door panels off to install speakers a few weeks ago and it seems like that window trim strip just snaps in.
Old Aug 10, 2006 | 06:57 PM
thegame's Avatar
thegame
No, Not the door, on the very top where the window rolls up. Right under the roof.
Old Aug 10, 2006 | 07:41 PM
rcs128's Avatar
rcs128
I guess this is what you need? Sit down before you look at the price. Per side. Gulp.
http://www.madvet.com/shop?frame=1.162.3519
(some other vendors might have it for less... shop around)
Old Aug 10, 2006 | 07:53 PM
thegame's Avatar
thegame
I am going to bookmark that page. Thanks for the link, the item D is what I would need. First I am going to check tomorrow if I still have warrenty on my car because I believe the previous owner said that it's valid untill December.
Old Aug 10, 2006 | 11:25 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
They are cheaper at Fred Beans - www.fredbeansparts.com
To C5 window problem
