B&B Bullet installation
Old Aug 10, 2006 | 10:41 PM
Surfballs69's Avatar
Surfballs69
Default B&B Bullet installation
I've been having a lot trouble with the B&B Bullets ever since I bought them. I've sent them back twice only to see the problem not fixed correctly. They finally sent me a whole new exhaust and now I'm having trouble with the install. The new system that they sent me uses clamps in between the two pipe sections. I connect the pipes together and then tighten the clamp, but when I start the car I can tell it's leaking right away. I've taken them on and off the car so many times to try to figure out what I'm doing wrong. Does anyone have their newer system that uses the clamps? If you do, how did you prevent the exhaust from leaking where the clamps are? Is there a precise way of putting it on to prevent it from leaking?
Old Aug 10, 2006 | 10:48 PM
02gt350's Avatar
02gt350
i have newer ones. about 2 months old. i didnt have any leaks. make sure the pipes are not bent at the ends and the tip section is in the other pipe as far as possible and tighten it like a madman
Old Aug 11, 2006 | 12:49 AM
RonSS's Avatar
RonSS
I have had mine on for about 3 weeks now. They came with 3 inch band style clamps instead of flanges like in the picture on their website. No leaks at all for me and I feel having a slip joint made it easier to get the tips lined up.
Old Aug 11, 2006 | 12:04 PM
LF97C5Vette's Avatar
LF97C5Vette
Yeah mine has clamps too. Been a couple months since the install. I used an impact wrench to tighten it down... no leaks for me!
Sorry about yours - have you considered taking it to a shop, couldn't be more than $50 to get it installed.
GL to ya,
Dan
Old Aug 11, 2006 | 12:13 PM
Hammie's Avatar
Hammie
I ended up buying 3 inch NAPA Easy-Seal clamps when I had mine, since the B&B clamps stunk.
Old Aug 11, 2006 | 02:33 PM
matt420c's Avatar
matt420c
had mine on about a month now, they are clamp style, no leaks , easy install
To B&B Bullet installation
