Burning smell after driving???
Old Aug 14, 2006 | 09:25 AM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Originally Posted by angman5
Tires?
I like um well done
Old Aug 14, 2006 | 09:29 AM
07blackcoupe
Originally Posted by SultansDiamond
A clutch smell is distinct and different than an oil smell (or plastic bags). Kinda hard to describe other than to say if it isn't the clutch you would probably have a better indication from the smell what is the culprit since you don't smell the clutch often. Also it seems the clutch smell permeates and lingers more than other smells. You will notice it in and out of the car. It's not a strong or particullarly foul odor, but it does hang around.
Based on all the non-descript gibberish above... I would say don't rule out the clutch.
I agree, I really think it is a clutch smell. What does that mean, the stock clutch is almost 90 k old, does this mean that it will start to slip soon...
Old Aug 14, 2006 | 09:43 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
99magredcoupe:
Have you looked at the exhaust/headers (see my post on P1 of this post) to see if there is a plastic bag (probably melted by this time that is causing your issue?
Old Aug 14, 2006 | 12:39 PM
07blackcoupe
I did a quick visual from the back and from the engine down after reading your post here at work- I will jack up the car tonight based on your post and take a better look. Thanks
Old Aug 14, 2006 | 06:53 PM
SultansDiamond's Avatar
SultansDiamond
Been racking my brain to figure out how to describe the odor of a slipping clutch. Then it dawned on me...
Go to the bank and withdraw $1,300 in small bills go out to the parking lot place them in a crumpled pile and set it on fire. Take a good whiff and remember that smell!
Old Aug 15, 2006 | 08:38 AM
07blackcoupe
Do you think 20's will do the trick or should I use singles...
Old Aug 15, 2006 | 10:04 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Look at the rear end, around the exhaust, it might be the famous rear end seal starting to leak, and diff. fluid getting on the exhaust. Most probably the driver's side
Old Aug 16, 2006 | 01:29 PM
DAWS C5's Avatar
DAWS C5
Originally Posted by greg_nate
I've had the same thing since day one of buying the car new. Are they easily replaceable? I am going to look at mine today...what should I look for?
Its located behind the intake manifold, near the firewall. Can't really see it without removing the manifold. With a flashlight you can look down next to the firewall at the exhaust. Maybe able to see oil on the pipe. Mine was on the drivers side. My mechanic knew where to look.
Only difficulty in replacing is you must remove, or at least move forward the intake manifold to access it.
Sorry for delay in responding.
PS check out this thread: http://forums.corvetteforum.com/show....php?t=1472249
Old Aug 16, 2006 | 01:53 PM
Garrett W's Avatar
Garrett W
Maybe you finally stepped on it?
Old Aug 16, 2006 | 03:09 PM
07blackcoupe
Easy there youngblood... remember I was sticking up for you on your "welcome to the board, I am 14 years old and own a vette thread!"
Old Aug 16, 2006 | 03:35 PM
Garrett W's Avatar
Garrett W
Haha youre right i remember you now.
See i would give you some input but i dont know enough about cars to know about burning smells.
Anywayz didnt mean anything by it and i hope you get your problem fixed!
Old Aug 17, 2006 | 09:00 AM
07blackcoupe
Keep 'em coming, just don't expect to get away with anything!
