changing the fluid in the read end
Old Aug 11, 2006 | 03:11 PM
elctroman's Avatar
elctroman
Default changing the fluid in the read end
just got my 00 a4 and before i drive to caralisle this month thought i would change the flluid in the rear end .what do u recommend i should use .
Old Aug 11, 2006 | 03:49 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi elctroman -
I used Redline light gear oil - some like Amzoil and I think that is good stuff too.
Others use Royal Purple.
here is what your owners manual says -
And here are some pics that might help from when I changed mine out -
Here is how I used a hex wrench and a deep well socket for leverage -
detail of the plugs -
best regards -
mqqn
Old Aug 11, 2006 | 06:14 PM
vettesmith02's Avatar
vettesmith02
Thanks mqqn
Old Aug 12, 2006 | 10:48 AM
elctroman's Avatar
elctroman
thanks MQQN, im going to do it this weekend
Old Aug 12, 2006 | 11:10 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi guys-
You are welcome!
I forgot to mention that Amzoil, Redline and Royal Purple do not need the additional friction modifier specified in the manual.
I have personal experience with the Redline, and have read from other members here about the Amzoil and RP.
It's a 20 minute job with a $10 hand pump from walmart or autozone etc.
best regards -
mqqn
Old Aug 12, 2006 | 11:25 AM
GR8-LIFE's Avatar
GR8-LIFE
A4 or MN6? I use royal purple in my MN6 and it has been battle tested in the high heat conditions of the track
Old Aug 12, 2006 | 11:50 AM
SpeedUp's Avatar
SpeedUp
can the crush washer be re-used?
Old Aug 12, 2006 | 01:11 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Mark -
He is asking about the differential.
I did put RedLine in my trans too - it was easier for me to get, but I have heard good things about the RP products too.
In fact - if you do have a manual, it's easy to go ahead and change that fluid out at the same time - that takes DexronIII ATF - I used the Red Line -
here are some pics of that process -
http://www.iammoon.com/images/c5tech/transoil/
02vert -
I re-used the crush washer and have had no seeping or leaks.
best regards -
mqqn
To changing the fluid in the read end
