[Z06] Steering ratios
Old Aug 14, 2006 | 08:55 PM
froggy47's Avatar
froggy47
Default Steering ratios
Does z06 have a faster steering ratio than regular c5?
Faster than late model c4 (like the 1996 LT4 coupe
TIA.
P/s pump different/ p/s cooler?
Old Aug 15, 2006 | 01:50 PM
Zo3o6's Avatar
Zo3o6
Old Aug 15, 2006 | 04:28 PM
rwd's Avatar
rwd
No.
All Corvettes since 1990 have the same 16 to 1 ratio. The reason the C4 feels faster is that the wheelbase is nearly a foot shorter.
The 1989 coupe Z51 was the last quick steer (13.3 to 1) made.
Old Aug 16, 2006 | 11:48 PM
froggy47's Avatar
froggy47
Originally Posted by rwd
No.
Mine (1996) feels slow, so I guess no improvement with the z06.
Old Aug 18, 2006 | 04:20 AM
rhneff's Avatar
rhneff
No.
My Z06 "feels" quite a bit faster than my 96 coupe, even though the steering ratio is the same 16.1:1, perhaps because of the MagnaSteer feature.
I have a related question: the steering ratio is the same 16.1:1 for the coupe and convertible as for the Z06, yet the turns lock to lock for the first two is 2.66 and for the Z06 is 2.46 - any idea why/how that is with the same ratio?
I assume it's because of the larger wheels/tires on the Z06, and is also related to the difference in turning diameter (larger for the Z06). True?
Old Aug 18, 2006 | 11:57 AM
froggy47's Avatar
froggy47
How does magna steer work?
Old Aug 18, 2006 | 02:01 PM
rhneff's Avatar
rhneff
As I understand it, the rack & pinion in the C5 has variable-effort boost that provides continuous speed-sensitive changes to the steering effort needed. I don't know exactly how they do that, but the system calculates vehicle speed and lateral acceleration and uses a combination of hydraulics, electronics and magnetics to vary the steering boost according to what the car's doing. It seems to provide a much more sensitive feel than my C4 ever has, especially when autocrossing.
First time out on course in the C5 I hit three of the five cones in an opening slalom by turning in where I always had in the C4 - the Z06 responded so much more crisply I had to change how I drove to get through it. The LS6 isn't the only reason the Z06 is much quicker than my LT4 coupe .
Old Aug 18, 2006 | 04:46 PM
froggy47's Avatar
froggy47
Thanks, that'll be sweet. I always feel like I am muscling the LT4 thru slaloms.
To Steering ratios
