[Z06] Need help on heads
Old Aug 15, 2006 | 09:48 PM
SteveDM's Avatar
SteveDM
Default Need help on heads
What are the best set of budget heads out there? I have a cam and headers but looking to upgrade my 04 Z. 205 vs 225cc?
Old Aug 16, 2006 | 06:49 AM
PA Z06's Avatar
PA Z06
The cheapest I have seen a patriot heads, stage 2 and 3 complete for around 1,100 or 1,200.
Old Aug 16, 2006 | 01:34 PM
ridered007's Avatar
ridered007
Go with AFR 205's. Tony Mamo there can hook you up with your current set-up. 877.892.8844
I have a very mild cam, cheap LT's and bolt-ons and make 440/397 to the wheels. I produced over 305RWTQ from 2250prm on!!!
Let me know if you have any questions.
Thanks,
J.R.
Old Aug 16, 2006 | 04:57 PM
zeevette's Avatar
zeevette
AFRs are far from "budget" heads. You refer to 205/225, and these port size choices are AFR. The 225 size is for larger bore, or is available in small bore, but not recommended for street applications. If you truly wish a budget head, shop Texas Speed, Livernois, SDPC, which have ported factory versions and Patriot, which are available from several vendors.
Old Aug 17, 2006 | 06:30 PM
chimazo's Avatar
chimazo
Also check out Livernois heads.
Old Aug 17, 2006 | 08:24 PM
zo6vetteman2003's Avatar
zo6vetteman2003
An LS6 head with a Stage 1 port is 215cc/80cc. They are extremely affortable right now, well under $700.00.
To Need help on heads
