Tire question----
Old Aug 15, 2006 | 10:44 PM
Qcksilverc5's Avatar
Qcksilverc5
Default Tire question----
I currently have the GY run flats and I'm looking for a new tire when I get the next set. The Kumho run flats look good. My question is- if I get the Kumhos, will the tire pressure sensors/DIC still work? Excuse me if it is a dumb question but I usually get great help here. Thanks in advance!!
Old Aug 15, 2006 | 10:47 PM
01vetter's Avatar
01vetter
Yes
Old Aug 15, 2006 | 10:48 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Yup
Old Aug 15, 2006 | 10:55 PM
MYCoupe's Avatar
MYCoupe
Just make sure you keep the wheels in the same location on the car when you mount the new tires. Otherwise, you'll have to retrain the sensors.
Old Aug 16, 2006 | 08:41 AM
Yes, they will work just fine. Go for it.
Old Aug 16, 2006 | 08:44 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
I didn't keep my wheels in the same location and I didn't have to retrain my sensors...maybe I got lucky? To quicksilverc5, the answer is yes, and make sure you tell the tire tech you have wheel sensors, some are not so smart!
p.s.-Kuhmo's are OK, Michelin pilot sport A/S ZP are better!
Old Aug 16, 2006 | 09:21 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by The Nuts
I didn't keep my wheels in the same location and I didn't have to retrain my sensors...maybe I got lucky? ...
Nuts...
That's ok, the car doesn't know that... however if you let the air out of one of the tires (one that got moved) it will display on the instrument panel in its previous location.
You probably should retrain them so you don't go looking for a flat tire only to find it has all of it's air...
GUSTO
Old Aug 16, 2006 | 09:28 AM
Qcksilverc5
Thanks so much guys !! I REALLY appreciate all the input.
Old Aug 16, 2006 | 10:17 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Originally Posted by GUSTO14
Nuts...
GUSTO
I let air out if one of my tires to check if it was working correctly after I installed the tires(I'm an ASE technician) and drove it around for about a mile and it correctly showed the pressure after a 1/4 mile...so, I must be lucky
Old Aug 16, 2006 | 10:28 AM
GUSTO14's Avatar
GUSTO14
Then they obviously didn't get mixed up when they were changed out.
Since you are an ASE technician, you know, the computer only knows the order in which you train the sensors... LF, RF, RR, LR... If you were to train them in reverse order, the DIC will simply display the left rear tire pressure in the right front position on the DIC... etc. Therefore they must not have gotten switched around...
GUSTO
Old Aug 18, 2006 | 10:22 PM
Mad_Maxxx's Avatar
Mad_Maxxx
GUSTO
HUH? I just cross rotated the left wheel w/ the right wheel w/ the sensors still on them, I KNOW for a fact the sensors and wheels WERE NOT in the same location as they were prior to my swap, and they're working perfectly, I personally swapped them and know where the sensors were and being a qualified and capable technician I think I'd remember if the sensors were in their original position, thank you. My point is I didnt have any trouble "training" them, they "trained" themselves after driving it less than a mile
Old Aug 18, 2006 | 10:35 PM
DngrZne's Avatar
DngrZne
Any chance that they were reversed prior to your rotating the tires? The computer only knows which wheel is which because during programming it tells you when to activate each sensor on a specified wheel with a magnet. That would be the only thing that would make sense for it to work as you described. Otherwise the computer would still read the pressures, but would read them at incorrect locations.
Chris
Old Aug 18, 2006 | 11:17 PM
thisMSGgood4me's Avatar
thisMSGgood4me
That doesn't make any sense, the sensors can't "train" themselves. Could someone else in the shop have done it for you and you not know about it?
Old Aug 18, 2006 | 11:45 PM
rgtkst's Avatar
rgtkst
the sensors can get backwards on their own. mine did it a month or so ago. had to have the shop reprogram them. the pass side front was low and the dic reported it as the driver side front. i know it was reading correctly the week before because the passenger side had a nail in it and i put off getting it fixed for a few weeks and had to keep inflating it every few days. the shop had just done the latest recall for the column lock and i figured that reprogram had messed the tire monitor sensors up. the mech seems to think differently, but reprogrammed them for me for free. the odd thing is the rears always read correctly
Old Aug 19, 2006 | 08:33 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Chris
No, the wheels were not reversed prior to crossing them left to right. The fact of the matter is the wheels were crossed unintentionally by one of our tire technicians when I put new tires on them. I know about the computer and training the sensors, and I thought I needed to bring out the big magnet, but after a 1/4 mile or so the pressures were spot on with my digital tire gauge. And no, noone else trained them, I'm the only one in our shop that knows anything about vettes!
To Tire question----
