Wheel size matters
Old Aug 16, 2006 | 03:40 PM
gmlefty's Avatar
gmlefty
Default Wheel size matters
I have an 04 MY Coupe that i would like to put some new tires and rims on. What size looks best in your opinion?
Feel free to post some pix to help me decide.
Was thinking about 19 or 20 Inch. (Maybe)
Old Aug 16, 2006 | 03:43 PM
HummelS's Avatar
HummelS
18F, 19R is as big as I'd go personally. I don't care for the look of 20's, and I think 19's all around doesn't look right. Just a personal preference.
Old Aug 16, 2006 | 03:52 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I have 18's and 19's....
Old Aug 16, 2006 | 03:57 PM
Garrett W's Avatar
Garrett W
I went with the 19-275 / 20-305
Lowered it on stock bolts. I want to lower it more.
But I think it looks great.
I did notice my car slow down a bit with all the weight though. But i get better traction so theres lots to consider.
Sorry about my oversized photo, too lazy to fix it.
gmlefty's Avatar
gmlefty
Default pix
Does anyone have some pixs of the 18s and 19s?
Also, what size tires fit best. I like the wider look without sticking out too far.
Old Aug 16, 2006 | 03:59 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
I have 19s all the way around.
Old Aug 16, 2006 | 04:03 PM
gmlefty's Avatar
gmlefty
Default Nice
The 20 inch rims seem to fill the fender well up nice!!
the 19s all the way around look sharp as well
Decisions Decisions
Old Aug 16, 2006 | 04:07 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
To me, the ideal size of a wheel has to do with the size of the fender opening on the car. The "perfect look" is when the circumference of the wheel exactly matches the radius of the fender opening. Most people probably don't realize this, or really know why some setups look better then others, or why a wheel can look too big, or too small on a particular car.
In my opinion, the 19/20" wheels are the optimal sizes that match the curve of the C5 fenders. They just look like they belong there,
20's on the front look too big, and the stock 17's look too small.
Here's my setup - Iforged Evolution 3pc wheels, 19x9.5" front and 20x10" rears.
Old Aug 16, 2006 | 04:19 PM
80535's Avatar
80535
Default tire size
what size are the tires? the car sits perfect, long bolts rear? remove the front?
Old Aug 16, 2006 | 04:30 PM
gmlefty's Avatar
gmlefty
Default Y2Kvert4me
Y2Kvert4me
what size are your tires? That is the look I like!!
(If I can swing the cost) Where did you buy those rims & Tires?
AWESOME
Old Aug 16, 2006 | 04:39 PM
99FastLane's Avatar
99FastLane
If you change the wheel size do you have to adjust the speedometer?
Old Aug 16, 2006 | 05:10 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Wheel size isn't quite the issue, in a manner of speaking. It depends on how close the circumference (sometimes called the rolling diameter) of the new tire matches that of the old tire. This is why when you increase your wheel size (diameter), you decrease the new tire's profile size. If you get within a couple of %, it really won't matter (of more importance than your speed is that your odometer will be off IMO).
Old Aug 16, 2006 | 05:22 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Y2Kvert4me
AWESOME
275/30/19 front and 285/30/20 rear.
Bought the wheels direct from Iforged. Tires are Pirelli Pzero's from the Tirerack.
The tire heights are about identical to the stock tires so there is no speedometer error or any other problems with traction control, etc.
Car has been lowered with cut front bushings and longer rear bolts.
Old Aug 16, 2006 | 06:13 PM
Darion's Avatar
Darion
I like the look of the 19/20 combo best but the tire selection is really limited, only a few.
The 18/19 combo looks good to me with a better selection of tire sizes and manufactures, I like this choice for look.
18/18 combo is good for tire selection and range of sizes. Also if price point is an issue 18/18 combo's can be had at a much lower price point.
I will say that I like the 18/19 combo best but when considering all the options the 18/18 combo looks good also. JMHO
Old Aug 16, 2006 | 10:54 PM
I've got 19s in the front, 20s in the rear and think they look great. My other choice would have been 18/19.
Old Aug 16, 2006 | 10:58 PM
elemon's Avatar
elemon
Forgeline VR3P full polished
Old Aug 17, 2006 | 12:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
18x9.5/19x11s here.
305s fit perfectly in the rear without sticking out with these wheels. 265/35 or 275/35 work well in the fronts.
To Wheel size matters
Old Aug 17, 2006 | 08:58 AM
steck's Avatar
steck
^^^^works for me !!!
Old Aug 17, 2006 | 09:02 AM
steck's Avatar
steck
Otherwise known as RPM's.....rotations per mile. agree, get it with 1 or 2 percent of original rpm's and your speed and speedo will be out just a little ( say 98 miles per on speedo, when actually doing 100 or vice versa)
Old Aug 17, 2006 | 11:17 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I agree. All the cars picture above so far in this thread look great....
Decisions Decisions
It is NOT the 20" wheel that fills the fender up as it is the overall diamater tire you select... When you go with a 20" wheel, you'll be looking at some extremely low profile tires........
You can fill up the fender just as well with an 18" wheel as you can with a 20" wheel, it's the tire you choose that makes all the difference....
