I'd go with non-runflats myself (probably Goodyear GS-D3s or Firestone Wide Ovals), but if you want to stick with runflats, consider the Firestone Firehawks. I have a set and they hold the road pretty well.
I've had the GS-D3's on for about 3K miles now and love 'em
Of course, I've managed to pick up a nail in the right rear already . But the plug kit, and compressor, I bought worked great! My biggest concern is that the tire goes flat with the pressure sensor on the "bottom" and gets ruined
02Vert, I do believe that there are newer sealent kits that don't harm the sensors, but I personally wouldn't use it. Like I said, the plug kit and compressor worked fine for me.
I'm also a non runflat convert -- just installed a set of GY GSD3s and what a difference! Carrying a low profile jack, NAPA tire plug tool and the Conti air compressor from Tire Rack. I feel the same way -- would not use the sealant for other than last resort. Was your puncture a slow leak? Were you able to plug the tire on the car? I'm always a little concerned about a front tire completely deflating and getting some quarter panel fiberglass damage if the car rubs on the ground.
