Show some creative mounts for Escorts
Old Aug 16, 2006 | 10:18 PM
jrprich's Avatar
jrprich
Default Show some creative mounts for Escorts
Would like to see some pics of creative mounts for Escorts and V1s
Show your solutions
Old Aug 16, 2006 | 10:24 PM
Flight Test's Avatar
Flight Test
Cruise-In II Veteran
Sorry, no pics. I mount my V1 the old fashioned way, I use the suction cups on the windshield.
Old Aug 16, 2006 | 11:08 PM
DirteeDave's Avatar
DirteeDave
Check out the VetteMods solution. This is a great product. Beats the hell out of the suction cup mounts.
http://forums.corvetteforum.com/show....php?t=1452337
Old Aug 17, 2006 | 09:38 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Just installed the Vettemods mount last week - before I have used velcro to mount it on the dash, just above the center vent. I have noticed a little more vibration with the Vettemods mount than I'd like, so I will be modding it - I am going to add some foam between the top of the detector and the mount arm (I bought one of those foam paint brushes to harvest the foam from). Other than the vibration I really like it.
Old Aug 17, 2006 | 11:06 AM
PeterNLois's Avatar
PeterNLois
I have continued to use the suction cup mount at the top left center of the windshield with an Invisicord so the Escort can remain on the left side of the mirror. The hard mount that is now available by Vettemods looks like a first class product but puts the display too far out of my view for my taste. Unfortunately, the suction cup mount requires frequent maintenance, especially with the heat on it and wants to sag and fall down. Hopefully a hard mount for the left side becomes available that does not obstruct the mirror. Just my $.02 worth.
Old Aug 17, 2006 | 11:09 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Go to West Coast Corvettes WEB site.
They have a 'screw' that replaces the mirror to windshield screw.
Cost a bunch of $$$ for a damn screw, but it does work well, and keeps the radar unit just below the rear view mirror.
Old Aug 17, 2006 | 02:43 PM
vettemods.com's Avatar
vettemods.com
Former Sponsor
St. Jude Donor '06
Here you go!
C5 Escort & Valentine One visor mounting bracket
Available in Brushed or Black
VŌZtech has designed and manufactured this unique radar detector mount with a mounting tab that enables its use with both Escort and Valentine One detectors.
This item is fabricated from aluminum so its sturdy, reducing bounce and vibration. This bracket attaches to the passengers visor clip placing it just under the tint line on the windshield, while making it less visible from outside of the car. Also, as shown above, you are still able to place the visor in the down position. The VŌZtech radar detector bracket uses the visor clip screw to hold it securely in place.
C5 version $25.00
Old Aug 17, 2006 | 02:48 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
My vettemods bracket with an Escort 7500 powered by an 8" invisicord wired to the rear view mirror power.
Old Aug 17, 2006 | 02:49 PM
vettemods.com
Former Sponsor
St. Jude Donor '06
ptdrummer54
The vibration should be very minimal. Please make sure the visor clip is seated fully into our bracket and that the detector has "clicked" into the slot on the mounting tab. If those things are done and you still have an issue shoot me a PM.
Thanks,
Rick
Old Aug 17, 2006 | 03:04 PM
byte_me's Avatar
byte_me
mine also vibrates while I drive...trying to decide what to do about it...other then that- it fits great along with my rear view wire tap...you can't see it from the outside and it is not intrusive to the passenger (where it mounts to the visor clip)
Old Aug 17, 2006 | 03:31 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Not to be off topic or anything, but just a quick glance at the title and I was like .
Old Aug 17, 2006 | 03:42 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
thanks , just place my order!
Old Aug 17, 2006 | 03:48 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Originally Posted by vettemods.com
ptdrummer54
Thanks,
Rick
Hi Rick, Thanks, I think it is fully seated but I will check it again, as it was a firm fit... I'll let you know how I make out.
Old Aug 17, 2006 | 07:22 PM
jrprich's Avatar
jrprich
Suggestion, dump the suction cups and just use clear silcone seal to bond the stock Escort metal bracket directly to the windshield where you want it. I have done this on my last 4 cars, very stable, will not fall off, but easily removed with a razor blade. Just mark the location carefully with an erasable magic marker first, clean both the mount and the glass with alchol, put a layer of silcone seal on the mount surface and apply to the glass. Tape in place with blue painters tape overnight. then click in your Escort the next day.
Works great !
To Show some creative mounts for Escorts
