[Z06] X-pipe question
Old Sep 8, 2001 | 01:56 AM
Pio's Avatar
Pio
Default X-pipe question
I had a costum X-pipe installed on my Z06. The shop put it on right where the pre-cats used to be but kept the H pipe the car comes with.
A couple of my friends have gone to this shop and have done this mod with a nice decrease in e.t. I'm going back to the dyno on Monday to see if I get better than the 338 I got yesterday.
Do you think it would be better to get rid of the H? Have you (or heard of other folks) getting an x-pipe and keeping the H?
[Modified by Pio, 11:56 PM 9/7/2001]
Old Sep 8, 2001 | 03:45 PM
Pio's Avatar
Pio
Default Re: X-pipe question (Pio)
^ Anybody????? :jester
Old Sep 8, 2001 | 05:03 PM
CRAZYWUGLY's Avatar
CRAZYWUGLY
Not knowing anyone how has, I don't think it matters.
I may be wrong, but with the flow being equlized by the x-pipe, the "H" now has no major function. Flow will take the path of least resistence. I say don't worry about it.
:jester
[Modified by CRAZYWUGLY, 6:32 PM 9/8/2001]
Old Sep 8, 2001 | 05:35 PM
1UVAKND's Avatar
1UVAKND
The "X" Pipe is supposed to replace the "H" pipe to get the benefit from it.
Old Sep 9, 2001 | 12:31 AM
don527's Avatar
don527
Pio,
How does it sound with the X-pipe and with the pups gone? Dang, gotta find time and get together to hear that baby.
don
Old Sep 9, 2001 | 12:35 AM
Pio's Avatar
Pio
Default Re: X-pipe question (don527)
The sound is not that different at idle, but at WOT it ROCKS :smash:
Old Sep 9, 2001 | 12:48 AM
bwhitmore's Avatar
bwhitmore
I have never heard of someone putting an x-pipe in this area unless it replaces the cats completely in which case it would be considered "off-road" or non-emissions legal.
I run the x-pipe in place of my h-pipe, the small, inexpensive one. I can't legitimately say that makes any horsepower for me, but it does substantially reduce the popping I once had with my B&B Triflow PRT exhaust.
If you plan on replacing the h-pipe make sure you purchase a pipe that does not constrict the flow from two pipes to one pipe in that area. I have seen a lot of x-pipes recently in which it appears the two pipes cross over into a space that is really only one pipe in diameter, and then back to two pipes again. The one I have as well as the "bolt-on" types like the Corsa and Bassani don't do this, they have a space inside that is really quite wide, looking from the outside as if the pipes just came together and touched each other.
Old Sep 10, 2001 | 01:19 PM
MitchAlsup's Avatar
MitchAlsup
Once the flow has been balanced with an X-pipe, the H-pipe can perform no useful enhancement to the exhaust. If the H-pipe is after the X-pipe it can't even hurt the exhaust flow because exhaust pulses appear at both sides simultaneously, and there is no flow between sides.
Old Sep 10, 2001 | 11:54 PM
OPEN PLZ's Avatar
OPEN PLZ
Default Re: X-pipe question (MitchAlsup)
Hotrod had an article on X pipes. The jist of the article was that the close to the exhaust manifold you get the X the better. The H wont hurt you, may help a negligible amount.
Greg :chevy
To X-pipe question
