under drive pulley?
Old Aug 17, 2006 | 08:34 PM
pin75us's Avatar
pin75us
Default under drive pulley?
Any one using an under drive pulley? pros and cons of it?
recomend any vendors that pulley with the belts?
Old Aug 17, 2006 | 08:56 PM
pin75us's Avatar
pin75us
Default help
If anyone can help out with this it will be greatly appreciated. I am trying to decide if I buy just the belts or getting an under pulley kit.
Old Aug 17, 2006 | 09:02 PM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
Underdrive pulleys are known to give modest gains, but are generally done as part of a package. (eg. when swapping a more aggressive cam) I wouldn't go through the trouble (expense) unless I was already going to have the crank pulley off for another mod/repair.
Old Aug 17, 2006 | 09:07 PM
pin75us's Avatar
pin75us
I have a mechanic that will do it for $90 (install).
I need to get belts anyways. Will installing the underdrive pulley hamper the charging from the alternator?
Old Aug 17, 2006 | 09:16 PM
EdsC6Z06's Avatar
EdsC6Z06
The underdrive pulleys won't effect your charging or AC performance. At that price, you might as well do it. Good luck. (PS. Keep note of the "new" belt sizes for your next replacement.)
Old Aug 17, 2006 | 09:19 PM
pin75us's Avatar
pin75us
Thanks for the response.
Old Aug 17, 2006 | 09:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Since it's obvious he's never installed one on a C5 before. and probably won't even do it again for that price, it might be a deal worth taking.
Old Aug 17, 2006 | 10:43 PM
tiojames's Avatar
tiojames
Default UD pulley.
I would be cautious of the mechanic. It sounds like he is not familiar with C5s. The steering has to be loosened to get to the pulley. Also the crank should be pinned at the time of the install. You have to have a new bolt for the pulley, the old one is a one time only deal. Most shops that do C5s have a longer bolt to start the pulley on so as not to strip the crank snout or the new bolt. I would do a search here on the forum for pictures so you have an idea of the procedure. The UD pulley will work fine with the alt. and A/C.
Old Aug 17, 2006 | 10:52 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Pinning is usually only done with supercharged applications because of the much increased load on the pulley to drive the blower, which can overcome the press fit and spin the pulley on the crankshaft.
Just installing the pulley on a n/a car actually lessens the applied load, and makes it even less likely to slip than a stock pulley, so pinning is not at all eeded.
Old Aug 18, 2006 | 06:06 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Try TSP for your underdrive pulley. They have pretty good prices on them.
http://www.texas-speed.com/shop/item...d=629&catid=20
They are extremely friendly and sent mine out quick.
Old Aug 18, 2006 | 06:39 AM
Lancer033's Avatar
Lancer033
what I was told on here a while back, it's not worth the trouble unless you are doing a cam at the same time, but if you are doing a cam you might as well do it at the same time. I'm not sure I would trust a shop that would do it for $90.
Old Aug 18, 2006 | 07:30 PM
pin75us's Avatar
pin75us
Thanks for the advice guys.
Old Aug 18, 2006 | 07:34 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Here is a link of replacing my crank pulley.
http://forums.corvetteforum.com/show....php?t=1433407
Old Aug 18, 2006 | 08:06 PM
tiojames's Avatar
tiojames
[QUOTE=Y2Kvert4me]Pinning is usually only done with supercharged applications because of the much increased load on the pulley to drive the blower, which can overcome the press fit and spin the pulley on the crankshaft.
I'm not a C5 mechanic buy I will go along with Andy's(as in A&A) sugestion to pin the crank when you install a pulley. Not much work for a lot of security, cost me $50.00.
Old Aug 18, 2006 | 08:11 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
No
Not worth it if you have an auto (A4).
Not really worth it unless you have engine mods.
Old Aug 18, 2006 | 08:32 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by AC54ME
No
Why isn't it worth it with the A4? I had a H/C package and while there I told them to install the UD pulley. I hope I gained something from it.
SC5
To under drive pulley?
