P0803 Code
Old Aug 18, 2006 | 10:47 AM
Jumper's Avatar
Jumper
Default P0803 Code
I know it has to do with my CAGS. I have noticed that the car has been wanting to go into 4th at times and my clutch feels funny when I shift on occasion. When I purchased the car, it already had a CAGS defeat installed and worked fine. When I had headers and a tune done, the tuner reprogrammed it so the shift light did not come on and I thought he also programmed to not use CAGS altogther.
So the question is, why am I throwing the 803 code? If I just had the CAGS defeat, I know it can go bad. But if the PCM does not even try to use CAGS at all, then a defective CAGS defeat should not matter, correct?
Should I remove the CAGS defeat and see what happens?
Any suggestions are appreciated!
Old Aug 18, 2006 | 11:46 AM
HummelS's Avatar
HummelS
From the service manual: "Low system voltage can cause this DTC to set..."
Any chance your battery is going South?
Old Aug 18, 2006 | 12:10 PM
Jumper's Avatar
Jumper
HummelS,
I suppose that is entirely possible. It seems to crank fine, but it is still the original AC Delco battery so you never know I will have to have it checked since you mention that.
Thanks!
Jumper
Old Aug 18, 2006 | 12:17 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Check your alternator also.
Old Aug 18, 2006 | 02:31 PM
Jumper's Avatar
Jumper
Good idea Cozmo. I will be sure to have that checked as well.
Thanks!
Old Aug 20, 2006 | 01:55 PM
Jumper's Avatar
Jumper
Battery and alternator both tested fine. Guess I will try removing the CAGS and see what happens. If that doesn't help I will take it to the dealer.
Old Aug 20, 2006 | 06:13 PM
Stonecutter908's Avatar
Stonecutter908
Try posting over in the Tech section.
Old Aug 20, 2006 | 06:43 PM
Jumper's Avatar
Jumper
I removed the CAGS defeat and cleared the code. So far the Check Engine light has stayed off. The PCM was reprogrammed with the header install and tune so I don't need it. If everything stays fine this week, we will know it was something with the CAGS defeat.
Thanks for all the input.
To P0803 Code
