Early or Late Model 99?
Thanks in advance!
Steve
Steve
GM made 33,270 Corvettes in 1999.....http://www.corvetteactioncenter.com/...99/99prod.html...
atilla...
Steve
Any GM dealer can inquire the GM Vehicle Inquiry System (VIS) for your car's service history and build information, if you can just get them to. (You might find it best to ask someone in the dealer's service department.) The build information portion of the VIS inquiry will show your car's actual build date. Also, several members here on the Forum have access to the to GM's VIS. If you can't get your local dealer do this, start a new post requesting a GM VIS history/build info inquiry for your car and include your VIN in the post. Hopefully one of these members will come along shortly and run this for you.
HTH and Good Luck!
Would it be considered early or late model 99 being built in October?
Steve
Special RPO Codes
While VINs for each of the model years are supposed to be assigned in order, the VIN is an identification number and not a plant sequence number. Keep in mind that during each of the C5 production years, a number of containment, prototype and pilot vehicles for the upcoming model years were built on the assembly line alongside with the current model year cars. These containment, prototype and pilot vehicles were assigned a VIN for their respective model year and a number of these cars were later made into saleable vehicles. James Schefter wrote about this in his book, "All Corvettes Are Red."
I read an interesting letter on this subject that was sent to the editor of Corvette Enthusiast Magazine several years ago. The letter's author did not provide his credentials, but it was obvious that he was quite knowledgeable of the assembly plant's build and sequencing processes. He spoke briefly about how differently cars are built today versus back in the St. Louis days and the use of Job Numbers or Sequence Number as they appear on the C5's build sheet. He went on to state that the VIN is an Identification Number and not a "plant sequence number." He went on to say, "That is why VIN 00001 for 2005 can be built on the 2004 assembly line and have that ID number attached." He finished by saying, "So, plant sequence number or job sequence number has everything to do with the car assembly process and nothing to do with the VIN other than the two have a relationship, but do not match." You may be able to find a copy of this issue of Corvette Enthusiast at one of your local libraries. (See "Those Crazy VINs", in the "Enthusiast Notes" department, Corvette Enthusiast Magazine, October 2004, page 10.)
HTH
Steve
