Rocker panel question...
Old Aug 19, 2006 | 02:11 PM
Boomah's Avatar
Boomah
Default Rocker panel question...
Going to do a fix on my cracked rocker panel today & have a quick question for the experts... Any problems or gotcha's when removing this piece (it's a stock Z)? I mean it looks easy enough but realize nothing is ever as easy as it seems
TIA & Mahalo!!!
Mark
Old Aug 19, 2006 | 03:55 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Rockers are glued on at factory.
Have fun removing them
Old Aug 19, 2006 | 04:17 PM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
My rocker had to be fixed instead of replaced because to replace it, the top has to come off
Old Aug 19, 2006 | 05:57 PM
Boomah's Avatar
Boomah
Okay, so nothing is ever as easy as it looks holds true here!
Thanks for the good gouge gents, saved me from a lot of pain I'm guess'n
Mahalo
Mark
Old Aug 19, 2006 | 06:19 PM
ckd's Avatar
ckd
<---NEWB
Are you guys serious? My passenger rocker panel (maybe I'm naming this incorrectly, but the lowest panel on the car that runs parallel to the door sill I guess) is virtually impossible to removE? I have some rock chips I'd like to fix one day but not if it's that hard.
Old Aug 19, 2006 | 07:10 PM
flynbya2's Avatar
flynbya2
Originally Posted by ckd
<---NEWB
You can repair them without removing them by sanding/putty/ fiberglass/ filler or whatever means you chose, and more sanding and paint
How's that Noob?
Old Aug 20, 2006 | 01:55 AM
ckd's Avatar
ckd
LOL, thanks bro.
Old Aug 20, 2006 | 08:59 AM
jers98vet's Avatar
jers98vet
You can install a rocker panel on an frc without removing the roof panel. There is JUST enough room to slide it in by loosening the quarter panel bolts. Much easier with a friend helping.
Now replacing a quarter panel on an frc.....TOTAL PITA!!!
Jer.
To Rocker panel question...
