Cut rear bushing?
I like the way it looks, and I'm surprised it hasn't been mentioned very much. I also cut 2/3 of the fronts bushings. Still waiting for it to settle all the way. I'll take pictures and measure ride heights this evening. If anyone wants to see pics, I can post those too.
Measured at each jacking point on the rocker panels:
LF=3-15/16"
RF=4-1/4"
LR=4-5/16"
RR=4-1/4"
So, does this mean that I would have to RAISE the LF 5/16", RAISE the LR 3/16", and RAISE the RR 1/4" to balance left to right and maintain a 1/4" rake from front to back?
Or could I remove the RF bolt completely to compensate for the 5/16" higher side, and then be able to leave the rears where they are?
Anyone know how much you can drop by removing a 2/3 cut bushing? 5/16" by any chance??
Front
Rear
Overall
LF=3-15/16"
RF=4-1/4"
LR=4-5/16"
RR=4-1/4"
Next, make sure the front is square across. I did this by measuring the leaf spring to the A arm with it jacked up off the stand a little. (one side at a time) With the front springs set the same across the front, you can adjust the square with the rear because it's easier to get to them. Think of it like the car is a table and the wheels are the legs. If your measuring on a true level floor, your car right now is rocking on the RF and LR. You do what ever you have to do on the rear to get the front level (within 1/16") and get about 1/8"-1/4" rake in the car. On mine I have two different length bolts in the rear.
Remember, when the car is sitting square from the frame to the floor, it's square no matter what the bolts look like. Another way to tell is jacking up on the rear and see if both rear tires come off the floor about the same time. If not, you have some wedge in the car.
I made a simple tool to get very accurate measuements taking a short piece of threaded rod with a washer and nut. Stick the rod into the frame points and run the nut up to the frame then measure the nut to the end of the rod. Works great.
If you have any questions, PM me. I have over 10 yrs experiance working on stockcars and setting them up. lol
Low is the ONLY way to go ! ! ! ! !
Your Z looks awesome. I love that Electron Blue ! ! !
Mark
looks good
Thanks for the other comments from everyone!
In the sig she is setting lower because of the Hoosier tires. but on streets it still looks as low as yours. Check the fender to tire clearance in my sig, it looks like I have less than yours.
