[Z06] Visual difference between 01 and 02+ LS6's?
Old Aug 21, 2006 | 11:27 AM
JGreen's Avatar
JGreen
Default Visual difference between 01 and 02+ LS6's?
Is there any way to tell the difference between the '01 and '02+ LS6's? Mine was replaced in my '01, and I am curious if they used another '01, or updated (it was replaced in '03 through GM).
Old Aug 21, 2006 | 11:38 AM
stingray454's Avatar
stingray454
The exhaust manifolds are slightly different on the '02 and later, although they could have kept your original exhaust manifolds. Other than that, I can't think of any external visual differences - the rest of the changes are all inside the engine and can't be seen.
There must be a way to look up what year the engine is from the serial number or casting number on the block and/or heads though.
Old Aug 21, 2006 | 02:41 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
If this was done via warranty work then I would bet that they installed the 385 HP version.
Old Aug 21, 2006 | 04:10 PM
JGreen's Avatar
JGreen
That is what I was thinking too, but it would be nice to know for sure.
Old Aug 21, 2006 | 04:21 PM
Ranger's Avatar
Ranger
Not definitive, but check the MAF. If it has a screen, it's a 2001. The screen was omitted in 2002.
Here is the best portrayal of 01 v 02 Z06s. You'll need to wade through it for the visible stuff.
Ranger
Old Aug 21, 2006 | 04:38 PM
stingray454
Oh yeah - forgot about the MAF screen - good catch!
Old Aug 21, 2006 | 05:25 PM
RussBt's Avatar
RussBt
People pull the screen on the 2001 cars, plus it is possible that the screen could have been left in even if a 2002+ motor was installed.
Old Aug 21, 2006 | 06:01 PM
Ranger's Avatar
Ranger
True. Not definitive, but an indicative.
Another way is to read and new-post the ESN (engine serial number). Someone with access to the power train data base should be able to convert the number to a date of manufacture.
Another path is to use the VIN to pull the maint. history. Then use the PN on the motor to ID the year.
A final way is to dyno the motor and post the results. Owners will help ID the year by the numbers it produces.
Ranger
Old Aug 21, 2006 | 08:52 PM
JGreen's Avatar
JGreen
Where would I find the ESN? I looked on the passenger side head (like on my old vette), but there is no number there.
Old Aug 21, 2006 | 09:16 PM
Ranger's Avatar
Ranger
Can't tell you. I sold mine.
But here is a thread discussing way to differentiate an 01 and 02 Z.
Ranger
Old Aug 21, 2006 | 09:36 PM
hydro101's Avatar
hydro101
__________________
*** Car Hydraulics Newbie ***
To Visual difference between 01 and 02+ LS6's?
