Grinding Shifts
Old Aug 21, 2006 | 12:46 PM
DGW's Avatar
DGW
Default Grinding Shifts
I have 2000 M6 with B&M ripper shirfter 57K miles. I am driving it the same way I have for 6 years (never taken it to the track, only the ocasional mustang or fast and furious spanking) and it has started missing/grinding normal shifts into 2nd and 5th. The clutch seems to be working fine, no slipping from what I can tell. I suspect either low fluid or loose shifter. I know you cant "adjust the clutch" but is there anything I can do?
Old Aug 21, 2006 | 12:48 PM
EHS's Avatar
EHS
Like you siad -- fluid and shifter. Replace the fluid (your due anyway), and make sure the shifter is correctly adjusted.
Old Aug 21, 2006 | 01:29 PM
Ron Dittmer's Avatar
Ron Dittmer
Empty the clutch fluid reservior, wipe it out clean, refill, then bleed the line. That's the beginning for any clutch wonders.
Old Aug 21, 2006 | 03:10 PM
HummelS's Avatar
HummelS
On earlier C5's the aluminum shift forks sometimes get bent, causing the problem you describe. I think there is a TSB on this.
I hope the fluid change works for you, otherwise it's gonna be spendy....
Old Aug 21, 2006 | 03:19 PM
nwdanner's Avatar
nwdanner
I had a very similar issue on my '02, but with 3rd gear only. I had never missed a shift or power shifted the car. In the end, it wound up that one of the aluminum shifter forks bent, causing the 3rd/4th sychros to die. Fortunately, there was a TSB on the issue and it was fixed under the factory warranty. Without warranty, the repairs would have ran me ~$2500.
One more thing, right from the transmission tech...."Don't rest your hand on the shifter while driving as this can lead to premature synchro failure." Don't know the truth of this statement, but it's what I heard!
Old Aug 21, 2006 | 03:34 PM
EHS's Avatar
EHS
Originally Posted by nwdanner
...One more thing, right from the transmission tech...."Don't rest your hand on the shifter while driving as this can lead to premature synchro failure." Don't know the truth of this statement, but it's what I heard!
Well, yes, like so many things in life --
it's not where you rest your hand, it's what you do with it when it's there.
If you apply too much pressure, in any direction, it will cause a problem.
Old Aug 21, 2006 | 07:02 PM
Jay-rod's Avatar
Jay-rod
Change the fluid,I was having the same issue.I put in mobil 1,and the tranny felt o.k but stiff.Now I am running normal atf and it's perfect.JER
To Grinding Shifts
