[Z06] Loud aftermarket shifter?
Old Aug 23, 2006 | 11:27 AM
Ryan L's Avatar
Ryan L
Default Loud aftermarket shifter?
I picked up a TR '03 w/ 13k miles over the weekend and noticed it had a couple of minor mods. There is obviously an aftermarket shifter in it because its very short and I can hear alot of road noise and feel some heat coming off of it. Did the previous owner not install the rubber isolator correctly?
Old Aug 23, 2006 | 03:08 PM
axis8758's Avatar
axis8758
A lot of people mention that there is some noise with an aftermarket shifter when driving hard. My B&M was a little noisy till I tightend up my ****. Others have stated that an aftermarket **** with more weight will also solve the noise problem.
Old Aug 23, 2006 | 03:53 PM
Ryan L's Avatar
Ryan L
It's not really a vibration issue, but rather an amplified transmission or road noise. It sounds like its missing some rubber isolation.
Old Aug 23, 2006 | 04:35 PM
dbirdz06's Avatar
dbirdz06
I just bought my car and it had an aftermarket shifter installed as well. Very short, firm throws. Personally, I don't like it. My car is a daily driver so it becomes a bit much in traffic especially. I had ordered at C6 Z06 shifter before I knew the car had an aftermarket one so I have that waiting to be swapped out. I am looking forward to it. I will know what brand of short throw it is when I remove. It's noisy under heavy/full throttle for sure. Sounds like something is going to fall apart! Sorry I can't help you in fixing the noise problem (only thing I could say was buy a C6 shifter!) Good luck.
Old Aug 23, 2006 | 08:14 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
take it apart and look at it.... i installed the hust shifter last year and in the instructions they said i could cut the rubber boot or invert the boot.. so i inverted the boot and heard a bunch of noise that wasnt there before, so i thought i installed it wrong or something... so i took it apart and figured i would cut the boot slightly smaller then the housing and strech the boot over it.... put it back together and it eliminated 95% of the noise... so i would take it apart and see if it was inverted or if the boot was cut
Old Aug 23, 2006 | 11:29 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
My hurst makes noise too, but it's hard to hear anytime over the mufflers anyways (what?) Sorry but there are some posts here about adding something to dampen the vibrations. ***** help too, as my mod red oem was ok but the old school hurst style marble one i have now is very noisy... it comes off tomorrow for the track
Dave
Old Aug 24, 2006 | 01:37 AM
FourG63 97GST's Avatar
FourG63 97GST
my B&M is noisy. at first the **** was loose thats make it noisy, now its just the noise transfering through the shifter
Old Aug 24, 2006 | 02:44 AM
MarkT 2002's Avatar
MarkT 2002
Default c6 Z06 Shifter
Just put a c6 Z06 shifter in my '02Z and love it. Made a big difference, was easy to install (except for the killer c5 shift *** pin), is as quiet as the OEM shifter and is more comfortable.
I actually feel more confident powershifting with the new shifter which makes the car (or me) feel quicker. I definately recommend the c6z06 shifer mod for anybody that drives their Z as a daily driver.
MarkT
Old Aug 24, 2006 | 10:38 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by keith954
take it apart and look at it.... .. so i took it apart and figured i would cut the boot slightly smaller then the housing and strech the boot over it.... put it back together and it eliminated 95% of the noise... so i would take it apart and see if it was inverted or if the boot was cut
I agree. When I installed my Hurst, I trimmed the boot slightly smaller than the base of the shifter so that it was a tight fit, and I have no noticeable increase in noise.
If picture works, it looks like this...
Old Aug 25, 2006 | 07:26 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I just changed out my Hurst for the Six Shooter from MTI racing! WOW!! What a difference, not a rattle one and smoother but just as precise as the Hurst.
To Loud aftermarket shifter?
