If you use the above server, when the pic is uploaded you will get a URL (its address on the server) that you then add to your post, using the little postcard image on the toolbar (above the text entry area when you create a post) and pasting the pic's url into the popup window.
The Help Forum is the place you need to go for all your general Forum usage and "how-to" questions. You should find several threads there on how to post pics. If after reviewing these you need further assistance, post there and someone should be along to help you.
