fuel door
Old Aug 24, 2006 | 09:55 PM
01c5's Avatar
01c5
6th Gear
Default fuel door
Recently had my 01 Vert in for the repair to the AC illumination problem, and now the fuel filler door won't open. I can open it with the cable release, but the button doen't work, checked fuse, its OK. Any ideas?
Thanks, Dave
Old Aug 24, 2006 | 09:59 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I had the same problem the very day i picked my car up.
I later took the console apart and i think it was just the button was stuck down or something and it fixed it. Only took five mins,
Give er a try. Good luck.
Old Aug 24, 2006 | 10:04 PM
01c5's Avatar
01c5
6th Gear
Default fuel door
button seems fine, pushes in like normal, just doesn't work. Thanks for the reply.
Old Aug 24, 2006 | 10:15 PM
JB666's Avatar
JB666
Same thing happened to me after some stereo work... I took it back, and they forgot to snap the plug back in all the way...
Old Aug 24, 2006 | 10:23 PM
11yellowgscpe's Avatar
11yellowgscpe
When the console is removed the electrical connection in the console must be disconnected. Check the filler door switch connection. There are 4 screws inside the console to take out and you can check the connection.
Old Aug 24, 2006 | 10:44 PM
mrC5er's Avatar
mrC5er
Sounds like they forgot to plug the connector back into the switch.
Old Aug 24, 2006 | 10:49 PM
dragboatnolen's Avatar
dragboatnolen
I had this problem once with mine. We pushed on the outside door and got it open and the connector the gas cap was turned around and was jamming into the door, causing it to not open. Simple solution do a somewhat devastating problem (at least I thought so at the time)
Old Aug 24, 2006 | 11:01 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
when it doesn't work...
when it does!
Old Aug 24, 2006 | 11:18 PM
May want to check and see if the connector on the release button is connected. When they worked on the A/C, they may have unhooked it and forgot to put it back.
Old Aug 25, 2006 | 12:17 AM
Itchy's Avatar
Itchy
its the way they designed the plug to try and fit in that little pocket, if you have had the console out you just have to make sure the plug snaps back into place, it happened to me
Old Aug 25, 2006 | 12:43 PM
DRILL629's Avatar
DRILL629
i had a similar problem after having my ipod hard-wired. apparently the tech forgot to plug the loop that is activated by the fuel door release button. it can be checked and repaired in matter of 10to 15 minutes.
To fuel door
