Last night my headlights would not pop up and when they did the low beams did not work till I hit the highbeams a few times. Also the turn signals were working about half the time. Anyone else have this happen to them?
Jeff
Jeff
Can't help you with more than a TTT and a suggestion
you post in the Tech Forum for help. Given your description I don't think your dealing with a fuse problems. There have been a couple of recent posts concerning problems with preformance of the headlights and it turned out the cause was the column switch. Good luck.
