Run flat distance
Old Aug 28, 2006 | 12:09 PM
B's00Vette's Avatar
B's00Vette
Default Run flat distance
Where can I find info on how far we can drive on run flats before repair? I remember hearing the goodyear's are 250 miles, but others are only 50 to 100 miles. Is there a list somewhere?
Old Aug 28, 2006 | 12:23 PM
wamara's Avatar
wamara
Cruise-In II Veteran
I suspect the respective manufacturers would be your best source of information.
Old Aug 28, 2006 | 12:57 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Check tirerack.com for the tire you have and look at the specifications
Old Aug 28, 2006 | 01:02 PM
OEM Goodyears (the original ones) were good for 200 miles then replacement was needed. The newer generation Goodyear runflats (those on the C6) are good for 100 miles. Firestone Firehawk runflats can go 50 miles. Not sure about the Michelins.
Old Aug 28, 2006 | 01:13 PM
GrayC5's Avatar
GrayC5
The GY EMTs for the C5 are only rated at 200 miles for run flat incidents. My understanding is that the newer generation GY EMTs used on the C6 are rated for 100 miles, but these currently are not available in C5 sizes. Also, several manufacturers say their run-flats are not to be repaired after any run-flat incident and must be scrapped. See about 3/4 ways down in the article below.
Run Flat Facts
Old Aug 28, 2006 | 02:12 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Michelin recommends no more than 50 miles on their Pilot Sport A/S Zero Pressure tires.
Old Aug 28, 2006 | 03:28 PM
B's00Vette's Avatar
B's00Vette
Originally Posted by GrayC5
That article is exactly what I needed. It looks like only the goodyears will go over 50 miles when flat. But they are also the loudest. So I guess I need to search for some sound proofing material now.
Thanks.
Old Aug 28, 2006 | 04:26 PM
rws.1's Avatar
rws.1
... or buy a tire plug kit and a 12V air compressor....
Old Aug 28, 2006 | 04:57 PM
Old Man in a C's Avatar
Old Man in a C
Just my experience, but:
Before I got rid of my runflats, I had a flat. Fortunately I was able to plug it and go, within a mile or two.
Driving on a deflated runflat was like chalk on a blackboard. You may be safely able to limp 100 - 200 (whatever) miles, but I can't imagine ever running that tire at high speed again.
Get a plug kit and compressor and then get some decent tires.
$.02 deposited
To Run flat distance
