help with VIN
Old Aug 29, 2006 | 12:47 PM
evil chevy's Avatar
evil chevy
Default help with VIN
Hi,
I'm about to buy a 2004 Z06, but don't know if the steering column recall was done and the service history.
I think all this can be check with the Vehicle VIN
can someone helpme
Old Aug 29, 2006 | 12:56 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Originally Posted by evil chevy
Hi,
can someone helpme
What's the vehicle number?
Old Aug 29, 2006 | 06:13 PM
evil chevy's Avatar
evil chevy
1G1YY12S845117701
thanx
Old Aug 29, 2006 | 06:29 PM
spiral04's Avatar
spiral04
Call your local chevy dealer. Explain to them that your buying a car and be polite, ask nicely and they should tell you all the things that the vehicle's been in service for.
Old Aug 29, 2006 | 06:36 PM
evil chevy's Avatar
evil chevy
I live in united Kingdom so no much chev dealer around here....
Old Aug 29, 2006 | 06:43 PM
spiral04's Avatar
spiral04
You do have a phone, don't you??
Old Aug 29, 2006 | 09:27 PM
Sponge Vette
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2004 CORVETTE Z06 Warranty Start Date : 04/26/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : ALLISON S, INCORPORATED
PO BOX 518
SYLVA , NC 28779-0518
(828) 586-4016
Closed Recalls:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 04/26/2004 7 miles 04/26/2007 36007 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/01/2006 097156 # C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 7472 miles
08/01/2006 097156 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 7472 miles
08/01/2006 097156 # R0942 - SPEAKER, RADIO - FRONT DOOR - RIGHT - REPLACE 7472 miles
12/02/2004 044530 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 677 miles
12/18/2003 A17701 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1614 kg (3559 lb)
Order Number : GRHTQC
Build Date : 12/18/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE4 - RIDE & HANDLING SUSPENSION SYSTEM FE9 - 50-STATE EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IP4 - TRIM INTERIOR DESIGN - AR9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS6 - 5.7L LITER SFI V8 - 405HP MN6 - 6-SPEED MANUAL TRANSMISSION
M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT P12 - CAST ALUMINUM WHEEL
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
1SA - BASE EQUIPMENT GROUP 1SZ - PREFERRED EQUIPMENT SAVINGS
67U - MACHINE SILVER 70I - TORCH RED INTERIOR TRIM
704 - Z06 INTERIOR - TORCH RED
Old Aug 30, 2006 | 08:09 PM
evil chevy's Avatar
evil chevy
Thanx very much.
Just need to run a carfax and if its Ok I buy this car,
To help with VIN
