dic display
Old Aug 29, 2006 | 07:42 PM
spuds350's Avatar
spuds350
Default dic display
well, i was sick of the intermitant dic display" turn off car pull key wait 10 sec's". called a service mgr friend of mine at a local chev dealer, they took it in and found a relay sticking open between bcm and shift column. replaced, hopefully this stops any more messages
Old Aug 29, 2006 | 08:13 PM
Tom/99's Avatar
Tom/99
Install a column lock bypass, and that will eliminate the problem ever showing up again.
Old Aug 30, 2006 | 11:41 AM
spuds350's Avatar
spuds350
Default Dic Display
I'm Under The Impression That If Recall Has Been Done..which Mine Was Performed...you Can't Add A COLUMN LOCK BYPASS???
To dic display
