Can I ........
Old Aug 30, 2006 | 08:09 AM
Vassili's Avatar
Vassili
Default Can I ........
Put a HUD system in my 98' and at about what cost? And second, can I put a key shut off for the passenger side air bag, and at what cost?
Old Aug 30, 2006 | 08:12 AM
Lightgomez's Avatar
Lightgomez
I've never done it or actually "seen" it personally...but I have read of some members talk about it for about $300. Apperently you have to pull out the dash and all...
I will see if I can find a previous post about it.
Old Aug 30, 2006 | 08:43 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
The HUD can be retrofitted to your car, but you will need the HUD cluster, dashpad bezel the elusive 11 pin wire harness AND a later model instrument cluster, it'll probably cost you $400-$600 if you shop well. Labor is probably about a $100-130 unless you do it your self, which is what I did. I found it fairly easy, but I'm a seasoned technician. You don not need a HUD approved windshield to make this work. All in all, it was worth the effort, the HUD is VERY cool and makes me feel like Maverick in Top Gun !
Old Aug 30, 2006 | 01:27 PM
Yes, you can put a passenger side air bag cutoff switch in your car. Give Bob at Fichtner Chevy a call. Not sure about the cost.
Old Aug 30, 2006 | 02:55 PM
Streetgrime's Avatar
Streetgrime
Special windshield? so will the end result withOUT the special windshield be a Fainter image? IF not.. then why is there a special HUD windshield at all?
I would also like to do this to my '98
Old Aug 30, 2006 | 09:56 PM
Streetgrime
Found this on Ebay today.
http://cgi.ebay.com/ebaymotors/99-04...25074402QQrdZ1
get it .. then tell me if it work good :o
Old Aug 31, 2006 | 09:14 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
I believe that is the kit Forum member PaceThis was offering in a GP a couple of months ago. If so, kit is *very* complete and relatively easy to install. Just time consuming as the entire dash pad and related parts must be removed but included instructions are very good.
A very complete kit.
Old Aug 31, 2006 | 09:18 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I did the HUD retrofit in my 2000 and it went fine. My cluster was HUD ready so all I needed was the 11 pin harness, dash bezel and the projector. Cutting the dash is a piece of cake. There have been some excellent detailed install instructions posted. Get those, give yourself plenty of time and you'll be set.
Old Aug 31, 2006 | 10:26 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Stock w/shield works fine
I installed the HUD in my 2000 FRC and it was very easy. Pacethis offers a complete kit. I got mine from Gene @ the KARSHOP before Pacethis was selling his kits. The 11 pin cable is not readily available.
I have the standard w/shield and it works great.
Bob K.
Old Aug 31, 2006 | 10:28 AM
Ruz's Avatar
Ruz
As a person with the HUD in my car, I can say that if I didn't have it I wouldn't go through the work to put it in. Just my $.02
Old Aug 31, 2006 | 10:54 AM
j99vette's Avatar
j99vette
if you want to permanantly turn off the airbag get a 2.1kohm resistor from radio shack and solder it to the plug.
Old Sep 1, 2006 | 01:05 AM
Mad_Maxxx's Avatar
Mad_Maxxx
it's called "GM engineers"..and they're not always right!
To Can I ........
