Jack Stand/Elite Jack Puck Question
Old Sep 1, 2006 | 10:15 AM
nikolai's Avatar
nikolai
Default Jack Stand/Elite Jack Puck Question
I have the Elite Engineering jacking pads on the way, and I would like to know if anyone manufactures jack stands with the same type of contact point as this pictured jack.
I would like to use the stands on the pads when the car is up in the air, but I don't think the conventional V-type shape of the stands' contact point would work with the pucks. Does anyone know where I can find jack stands like this, or if they are even manufactured? Thanks.
Old Sep 1, 2006 | 10:46 AM
LarryW's Avatar
LarryW
I'm using a set of AC Hydraulics jackstands that have flattop posts (but they are by no means cheap: they're around a 100 bux EACH and I bought 4 of em ):
The two places on the web (that I know of) that sell them are:
ultimategarage.com
asedeals.com
The AC Hydraulics floorjacks are awesome too but also pricey; worth every penny IMHO
Old Sep 1, 2006 | 11:47 AM
wamara's Avatar
wamara
Cruise-In II Veteran
with Larry - only ones I'm aware of. Or else get out the welder and make your own
Old Sep 1, 2006 | 12:00 PM
nikolai's Avatar
nikolai
Thanks for the info guys...I'm not sure what I want to pursue. I am considering these now, even though they are on the high side.
Old Sep 1, 2006 | 12:01 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Check out this thread:
http://forums.corvetteforum.com/show....php?t=1484275
Old Sep 1, 2006 | 12:41 PM
wamara's Avatar
wamara
Jeff,
thanks for that thread link - interesting. This jogged my memory about a trailer jack stand I saw - something along these lines: http://www.rvpartscenter.com/Product...DID=45&CID=167
Any reason to be concerned about the fact that the post is threaded versus using a pin to hold it in place? For that matter, any reason to be concerned about this (or the "Elite" version) being made of cast aluminum?
BTW, the jack stand mentioned in Jeff's thread is a "Torin", not Turin, in case anyone is trying to find it.
Old Sep 1, 2006 | 12:51 PM
wamara's Avatar
wamara
So now this got me looking, and I found this Torin jack and jack stand both:
http://www.northerntool.com/webapp/w...=10-24689254-2
$120 for a set of four. Hmmmmm.
Torin also makes bigger versions of this mechanical jack/stand to hold more weight and which raises higher.
Old Sep 1, 2006 | 05:43 PM
nikolai's Avatar
nikolai
Thanks again fellas!
Old Sep 1, 2006 | 05:47 PM
beefaronie's Avatar
beefaronie
Can you not use the conventional jacks with the pucks??
I was thinking about buying some pucks, but now I might just keep doing it the way I have been doing it all along.
Old Sep 1, 2006 | 05:57 PM
nikolai's Avatar
nikolai
Yes, you can use conventional jacks with the pucks, but my concern is wanting to use jack stands with a circular contact point to them, as opposed to the Y or V shaped stands.
To Jack Stand/Elite Jack Puck Question
