Really depends on your current set-up and what you want from your car. The new T/C's are very efficient so the slip that you hear about is not an issue in this day and age unless you are looking at something big. I run 3.73 gear and a Yank SS 3600 TC. Driving on the street is just about stock feeling. Depending on what your looking for a trans cooler is a good investment when you swap the TC.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have the Yank SS3600 and 3.90 gears, but I disagree with Bob (16Again) - the slip is quite annoying at low speed and it is noticeable - especially in traffic.
But when you stand on it at any speed - you better be pointing straight
I am pretty much stock daily driver, with the performance gears. I was thinking abut new gears but was reading a little about stalls. I just like being trown back in my seat from time to time, and think a bit more of a powerful feel at launch and passing could be even more fun.
The stall will definitely do that. It will also give you shift extensions.
What do you think would be an appropriate stall for the stock performance gears?
Also, is this a job that I could do myself (I am OK with wrenches but not a lot of experience with the drivetrain but a fast learner), or would I need a profesional to install it?
Put some real gears (4.10) in there and you won't have an issue.
If you have a 3.15 gear, go with a 2800 - 3000 and you won't even know it's there. As for the install the whole rear section of the car needs to come down, if your not familiar with it, I would take it to a shop that knows how to do it. Anytime you put a higher stall TC in you should expect additional transmission heat, a cooler is just an ounce of inexpensive prevention.
What problems might I see with a 3800? In the description it said "hard hitting launch". That sounds kinda fun!!
Hate to disagree with those that say stall is annoying, but I have 3:42s with a yank 3500 and unless you step on it the stall is not noticeble in traffic. If you gas it the rpms do pick up, but in easy driving thru traffic is is not apparent at all.
You know, it's all relative. He asked for opinions, so I voiced mine.
I'll give you an example of relative opinions - coilovers and T1 sways. I have both, my car is slammed way, WAY lower than anyone else on this forum - yet it rides perfect to me. To others, it would be both too low and too harsh.
I think the SS3600 slips at low speed and it is not invisible. But to others, like yourself, it's perfect.
I really think that's way too much converter for your gears. Hard hitting launch is fine, gear it accordingly. If you want to use a 3800, install a set of 3.73 or 3.90 gears. If you call Yank and tell them your set-up and desires they will recommend the converter you should use. Also with a converter that big, a trans cooler is a must.
Geezz, NOW you all talk about this.. I just got my 3.42 in this week. Got not stall done, cuz I was told it ONLY helps at the start line and not at ALL speeds, or Hwy speeds. Now, Im learning it helps at ALL SPEEDS, including city/Hwy speeds... Now what do I do? Get the stall done and pay the same labor again ? Gotta find me some cheap labor
Originally Posted by oahuyahoo
So what is the solution to the slip?
There isn't one. Most people will tell you "you will get accostomed to it in 30 minutes and then it's like stock".
Personally, it bugs me in traffic, around car parks ('parking lots' to you Colonists ), and while parking. In other words, at very low speed (under 20mph). Once it locks up at 35mph, it is just like stock - no more slip.
Best advice I can offer is drive a car with a stall at low speed, and see what you think.
All that being said, I LOVE my stall..!! When it flashes, it's like being launched from a cannon!!!
