Flameball
Old Sep 2, 2006 | 02:48 PM
twistedb01's Avatar
twistedb01
Default Flameball
I just finished installing my new flameball shift ****. Is there any way or anything to get the shift boot up or to cover the gap. Right now I am still showing a few threads and the wire.
Old Sep 2, 2006 | 02:49 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Very !
Old Sep 2, 2006 | 03:09 PM
6Speeder's Avatar
6Speeder
Cut the shifter shaft a little bit shorter.
Old Sep 2, 2006 | 03:21 PM
QuikZilver's Avatar
QuikZilver
To keep the boot all the way up and to hold the wire against the shaft, I used an o-ring.
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Love the Flameball. Have a similar one in different color. IMO the best solution is just to go ahead and rip out the stock shifter and replace with a [ insert your favorite brand here ] aftermarket shifter. I like my Hurst a lot.
Nice work... just one more step!
Old Sep 2, 2006 | 05:23 PM
twistedb01's Avatar
twistedb01
Thanks for the advice! Any more?
Old Sep 2, 2006 | 05:52 PM
TripleBlackxThree
St. Jude Donor '07
My Hurst is quite a bit shorter, but I just used a short piece of double stick tape at the top of the shifter. It's held the boot in place for about two years now.
Old Sep 2, 2006 | 06:01 PM
Tom/99's Avatar
Tom/99
Old Sep 2, 2006 | 06:07 PM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
Roll the top edge inside of the boot and put a zip tie on it nice and tight. I have the same boot with the stock ****. This worked well for me.
Old Sep 5, 2006 | 03:11 PM
twistedb01's Avatar
twistedb01
Went down to Wal-Mart and stepped foot into the arts and crafts section. Found some sticky sided velcro.
Old Sep 5, 2006 | 05:14 PM
MADN3SS's Avatar
MADN3SS
Is this one of the lighted ones? If so, lets see a pic of it all lit up! I was thinking about doing this as well.
Old Sep 5, 2006 | 05:16 PM
CleteZ16's Avatar
CleteZ16
St. Jude Donor '09
I was gonna ask.. is the wire for the 150 Nitrous Shot, or somethin' else..?
Old Sep 5, 2006 | 05:30 PM
Virtual Geezer's Avatar
Virtual Geezer
Perfect solution, well done!
Old Sep 5, 2006 | 05:36 PM
twistedb01's Avatar
twistedb01
I wish, the wire is for the light. The **** has a tiny hole on the underside, which allows for a LED to be inserted. The wires are tapped into the traction control panel, so when I turn on the parking lights or headlights, it lights up. PIC is on the way. It is 5:35 p.m. here and my garage door faces west.
Old Sep 5, 2006 | 06:39 PM
TripleBlackxThree
St. Jude Donor '07
Another lighted pic... sorry, not a great shot...
Old Sep 5, 2006 | 06:43 PM
casisthefirst's Avatar
casisthefirst
Personally, I think anything other than stock-look shifter ***** are tacky and reminds me of honda civics or even old camaro's. Not for me, but I do like the glow in the dark look.
Old Sep 5, 2006 | 06:58 PM
TripleBlackxThree
St. Jude Donor '07
When I installed my first Hurst shifter with a custom ****, there was no such thing as a honda civic (there were Honda 90 motorcycles )
They remind me of old Camaros too, only that's one of the things I like about them; a touch of retro.
Funny, the only Honda I ever owned had a shifter that looked remarkably like the stock C5.
To Flameball
Old Sep 5, 2006 | 07:14 PM
Garrett W's Avatar
Garrett W
INHM deffinatly not fan of the "Flameball"
Old Sep 5, 2006 | 07:46 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Im installing a C6 shifter this weekend. I intend to to use a plastic zip tie under the boot. Im going to try that first before I send $50 on a new boot
Old Sep 5, 2006 | 07:56 PM
twistedb01's Avatar
twistedb01
You shouldn't need a new boot. The boot I have is exactly the same specs as the factory boot. As you can see there are a few ways to keep the boot up. Mine is also not pulling too tight when shifting. So you don't have to worry about that either.
