Help with option codes
Old Sep 2, 2006 | 07:41 PM
Fallz's Avatar
Fallz
Default Help with option codes
I went and looked at an 04 MSG copupe with 14 k used at a dealership. It is auto , 2 tops ect.... I wrote down the build codes from the sticker in the glove box , I need to match these up to see how the car is optioned so I can get your opinion.
Where can I match the codes to ?
Mike
Old Sep 2, 2006 | 08:07 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hi Mike - here is one list - many others if you google RPO Codes - http://home.fuse.net/corvette/rpo.htm
Old Sep 2, 2006 | 08:09 PM
Mr.DJ's Avatar
Mr.DJ
It's the same one that I was going to link to.
Old Sep 2, 2006 | 08:37 PM
Fallz's Avatar
Fallz
Thanks guys , I know it has the 2.73 gears in A4.
Ill post optional equip. when I can to see what you think.
I like the car , its clean , lot of stone chips on lower front bumper though. A small scratch on passanger side wdw. All body panels look straight , and no variance in the metallic paint.
Old Sep 2, 2006 | 09:42 PM
Fallz's Avatar
Fallz
How can I tell what is optional and what is std. on a base car from that chart ????
VIN# 1G1YY22G145107416
option codes:from build sheet LEFT hand column.
AAB-Memory package
AQ9-Adj. sport bucket seats w/leather trimmed seating surfaces.
CJ2-Air cond- electronic dual zone
DDO-Electrochromic mirrors inside rear , left outside rear
DL5-Roadside service info decal---WOW
FE9-50 state emissions
IL3-Trim int. dfesign ( AQ9)
K63-110 amp gen.
MXO-4speed auto /OD
NK4-Leather wrapped wheel
N37-Steering:power telescoping & manual tilt
SLM-Stock orders
UNO-am/fm w/cd player
UV7-Windsheild Antenna
U52-Electronic instrumentation
VM3-Consumer info label
XGG-front tire P245/45ZR17 BW SBR
1SB-Preffered eq group,mem pkg,twilight sentinel,electrochromic mirrors,inside rear and outside left,HU display,steering p/tele & man tilt.
191-Black int.
88u-Med. Spiral gray Metallic
Options from build sheet RIGHT hand column
AK5-Driver & pass airbag
BGR-Bowling green plant
C2L-Roof package , dual panels
DD8-ORSV
FE1-Suspension system soft ride
GU2-rear axle 2.73
JL9-4 wheel disk , anto lock brakes
LS1-5.7L 350 hp V8
M30-4 speed electronic auto. trans w/OD
NT9-Fed.Emis.Sys.,Tier 2 phase-out
QF5-High polished Alum. wheels
T82-Twilight sentinel
UV6- HU Display
UZ6-Bose speaker and amplifier system.
VCD-Vehicle info CD-....WOW
V73-Statement of vehicle cert. US/Canada
YGH-Rear tire p275/40zr 18 BW SBR
1SZ-preffered eq. savings
193-Black leather trim seating
Th Th TH thats all folks.....!!!
I'm going to have the dealer run VIN for service records from other GM dealer link.
Any ifo good or bad about this optioned car would be a big help from you guys/gals.
Old Sep 2, 2006 | 09:49 PM
Fallz's Avatar
Fallz
Is a carfax worth running ?
To Help with option codes
