How do I remove the back letters...HELP
Old Sep 3, 2006 | 05:10 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Default How do I remove the back letters...HELP
I have the brake light red letters on the butt of my car. How do you get the sticky stuff out of the letters.
Old Sep 3, 2006 | 05:13 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Kona!
I used Boo Be Gone... it came in a spray bottle, but it's pretty much a gel. Let it sit for a few minutes and then work the residue out.
I twisted a terry cloth towel and finished up using a twisting motion. The goop in the corners of the letters just takes a little more time/patience.
Dave
EDIT:::: I meant GOO Be Gone.... they only sell Boo Be Gone around Halloween...
Old Sep 3, 2006 | 05:16 PM
dajael
Guest
Posts: n/a
If you are saying that you removed the stick-on letters and want to remove the glue residue from the factory letter impression on the rear fascia then I would tell you to pick up some "goof-off", it's designed to remove glue and tar residues as well as paint overspray or other like materials. It will not harm your paint so long as you wash and wax (protect) the area in question right after using it. You could also try WD-40, it will also remove most adhesives from a painted surface.
Best of Luck to you!
Old Sep 3, 2006 | 05:31 PM
KonaVette's Avatar
KonaVette
Thanks for the tips ....you guys are the best
Old Sep 4, 2006 | 12:08 AM
jrose7004's Avatar
jrose7004
I'd use Goof Off.
Old Sep 4, 2006 | 12:33 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by jrose7004
I'd use Goof Off.
and try heating with a hairdryer....should come right off.
Old Sep 4, 2006 | 12:59 AM
I've always had good luck with WD-40.
Old Sep 4, 2006 | 06:07 AM
steve8's Avatar
steve8
WD-40 has worked for me removing a lot of nasty stuff. I'd certainly give it a try.
To How do I remove the back letters...HELP
