White Face Gauge Kit
Old Sep 3, 2006 | 06:02 PM
grunz95's Avatar
grunz95
Default White Face Gauge Kit
I was thinking of installing the white face gauge kit in my 99. I was reading the service manual and it looks really hard. Has anyone ever remove there gauge cluster?
Thanks In Advance.
Grunz
Old Sep 3, 2006 | 06:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Cluster removal is pretty easy. It LOOKS far more intimidating than it really is.
I used these instructions: http://www.vetteessentials.com/instr...zel_howto.html
Once you dig into it, you'll find it's not bad at all.
Old Sep 3, 2006 | 09:23 PM
grunz95's Avatar
grunz95
Thank you for the information. Did you install the bezels on your vehicle?
Old Sep 3, 2006 | 09:42 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Good instructions and being patient. You'll have no problems. A couple of tips:
1. Don't lay the cluster face down. Problems related to doing this so avoid.
2. Make sure you double check that the sweep needles are on the OTHER side of the stop pin. When I did my bezels, I didn't double check and ended up redoing.
Take your time and you'll be fine. Nice mod.
Old Sep 4, 2006 | 01:43 AM
BrianWe's Avatar
BrianWe
Tip 3. Move the console back as far as it will go and wiggle out the radio bezel. This will save you from disconnecting the gas door release harness which is a major PITA to put back in.
To White Face Gauge Kit
