LG Street Series install notes
Fit and finish looks great
pass side: plugs, coil pack, valve cover rem'd, only had to loosen the starter and the header slid down no problem(the mount tab will hit the starter) ---->be sure to torque the starter bolts prior to tightening the header bolts up top, also secure the O2 sensor wiring while the header is still loose
driver side: plugs, coil pack, ground(aft side of engine block) rem'd, header installs from bottom with ease
I'm going to have to fire up the car in the A.M. though open headers
if anyone has questions with the LG's feel free to post
