[Z06] Front brakes squeal!
- The brakes won't squeak after washing it, especially if you blast the hose into the front calipers really well. You'll probably see a lot of black oily crud come oozing out from under the Vette when you do this.
- The brakes won't squeak after some hard dashes from stop to 80MPH+. Not recommended for simply elimniating brake squeak.
- The brakes won't squeak (as much) after a nice hard stop or two.
All three points essentially "clean" the front rotors by water, centrifugal force, or by scraping them clean with the pads themselves. I bought a can of "anti-squeak" from AutoZ0ne, but hesitated against applying it since I had these horrible visions of corrosive chemicals fanning out from the wheels while driving, so now I just try and keep it clean. I often give it a quick blast from the hose before taking it out..
All that said, I'm currently biding my time before deciding on an upgraded caliper/rotor combo -- one that won't squeak, which I think is the only real solution. I may have to get headers before that though. Oh the decisions.
Has anyone else tried the anti-squeak, and does it work? Should Ryan and I just get new pads?
Unless you track your car, I would recommend it to anyone.
Hardly, and I mean hardly noticed the difference. Highly recommend them too.
I'll try what others said about the sudden stops and/or good brake cleaning. I don't want to have to change out the pads since they are basically new.
Trust me dude, nobody has "Cobra Brake Envy" on this board. Physics, physics, physics. Try to stop that overweight pig with smaller brakes, and dissapate the heat, and still have brake performance. Not possible. The brakes are big on that Cobra for a reason, too many pounds to pull down. Period. Sorry but face the brutal facts and get over it!
After two weeks put your stock pads back on. You will be amazed by how quiet they are and how easy the dust cleans off.
Just get a set of ceramic pads like everyone else.
MOVIT hasn't release their cermamic brake kit yet. Still being tested.
Rob
