[Z06] Where is the ECU/computer located?
Old Sep 5, 2006 | 03:59 PM
Ryan L's Avatar
Ryan L
Default Where is the ECU/computer located?
I am trying to figure out if the previous owner of my 03Z had a tune/chip installed. Where is the ECU/computer located for me to verify?
Old Sep 5, 2006 | 04:28 PM
Major Smoke's Avatar
Major Smoke
If you mean the Powertrain Control Module, it is inside the passenger-side front wheel well. However, knowing that won't help you as these cars don't use pluggable chips. Tuning is accomplished via external software uploads thru the OBD-II port.
Old Sep 5, 2006 | 06:21 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Exactly, you will not be able to get any info from looking at the ECM
Old Sep 5, 2006 | 09:07 PM
Ryan L's Avatar
Ryan L
I am thinking that I possibly have had a tune since the Vette won't force me to do the 1-4 shift, no matter how easy I drive. No mention even comes up on the dash. This is good news, but has me wondering if the PCM has been tampered with.
Old Sep 6, 2006 | 12:13 AM
03 Z-oh-6's Avatar
03 Z-oh-6
It's ironic you state this. I was going to respond to check the same things you mentioned until I scrolled down and read it. I had no idea my car had a tune until I had it dyno'ed. The car looked bone stock, but the A/F ratio was way to perfect for a stock tune. Then, I realized there was no "skip shift" light on the dash, that was just another hint of a custom tune. However, with what you stated, I'm almost positive you have a custom tune. I didn't like the idea of not knowing who tuned my car(even though the A/F looked good), so I had A&A tune it after I added an intake.
Old Sep 6, 2006 | 12:21 AM
Ryan L's Avatar
Ryan L
I am finding more and more mods every day. I tried to lower the Vette this weekend, but the front was already maxed out since there is a 0.5" gap between the top of the spring and locking washer. If it was untouched, the locking washer should've been flush against the top of the spring, correct?
To Where is the ECU/computer located?
